-   -   CV joint tabs (http://forums.pelicanparts.com/porsche-911-technical-forum/1078302-cv-joint-tabs.html)
chateau 11-16-2020 09:36 AM
CV joint tabs
Hi,
I have removed my inboard CV joints on my 84 3.2 and there were not any tab washers on the bolts.
Are these necessary?
The parts manual says that 4 are required, is this one on outboard and one on inboard on each drive shaft?
Thank you
gtc 11-16-2020 02:12 PM
Which part number are you referring to?
Rodsrsr 11-16-2020 03:29 PM
I think the Op is referring to these> https://www.eeuroparts.com/Parts/192418/Axle-Bolt-Lock-Plate-Rear-91133219100/
I don't see them on Pelican. They are needed and take 3 per side. You also need schnoor washers and new bolts.
Flat6pac 11-16-2020 05:56 PM
The 8x50 bolts on an 84 do not require washers but are required to be 12.9 hardness
In the PET the locking plates are used on the 10x50 bolts on the 86 and later.
Bruce
chateau 11-17-2020 10:07 AM
Bruce
Thank you for the info Bruce
