-   -   Help!!! Stuck on the side of the road (http://forums.pelicanparts.com/porsche-911-technical-forum/1078620-help-stuck-side-road.html)
stevepatfred 11-19-2020 06:16 PM
SOS! Was happily driving along music playing when I noticed a horrible noise...starter motor was constantly engaged with the key on or off...I quickly managed to pull over and disconnect the battery...now im stuck on the side of the road. Any suggestions? Thanks! Thinking itís the starter barrel. Is there a way to isolate the starter motor so I can limp home after a push start?
911 SLANT 11-19-2020 06:32 PM
I would call AAA tow and not chance anymore damage or fire.
stevepatfred 11-19-2020 06:34 PM
Theyíre on the way...thought Iíd trouble shoot if there was a way while I wait the 3 hours for the tow truck!
76FJ55 11-19-2020 07:31 PM
what year car?
stevepatfred 11-19-2020 07:32 PM
Originally Posted by 76fj55 (Post 11110324)
what year car?
83 sc.
stevepatfred 11-19-2020 07:34 PM
I assume the starter disengages when the engines running even if itís turning over? There wasnít a grinding noise. Just the sound of the starter and vibration through the gearbox.
Trackrash 11-19-2020 07:37 PM
Cam chains grinding?
stevepatfred 11-19-2020 07:38 PM
No engine running fine, just the sound of the starter, engine on or off starter constantly running
pmax 11-19-2020 07:39 PM
I say it's your ignition switch.
Time to tow unless someone knows how to hotwire.
stevepatfred 11-19-2020 07:42 PM
I agree. Ignition switch feels worn. Was hoping there might be a way I can disconnect the starter from the ignition switch and jump start it. But tow trucks only 30 minutes away now...so Iím committed to that.
stevepatfred 11-19-2020 07:43 PM
Originally Posted by 76FJ55 (Post 11110324)
what year car?
1983 SC
76FJ55 11-19-2020 07:43 PM
did you have your heat turned on?
No
76FJ55 11-19-2020 07:50 PM
Then I'm pretty sure it is the ignition switch. in which case you would need to disconnect the yellow wire from the starter.
If you do that, I would make sure the car is in neutral and the parking brake set, before reconnecting the battery. I would then just tap the battery lead to make sure the starter doesn't spin before making the full connection.
stevepatfred 11-19-2020 09:22 PM
Thanks for all the comments, disconnected the starter and all was ok. Jump started and drove home. A new ignition switch will be ordered first thing. Glad to be home!
76FJ55 11-19-2020 09:33 PM
Glad it worked out and you made it home safely.
stevepatfred 11-20-2020 06:48 AM
Quick question. Is keys reluctance to spring back to on after start a problem with the electrical or mechanical side of the ignition switch?
proporsche 11-20-2020 07:34 AM
Steve, you are ordering only the electrical portion of the ignition switch,correct?
Hello from Carlsbad in Czech Republic;-)the original one...;-)
Ivan
stevepatfred 11-20-2020 07:38 AM
Ivan
Hi Ivan! I imagine your Carlsbad is a little colder than mine! Ha. So the symptoms were the starter was engaged regardless of key position. This happened out of nowhere, I had been driving all day with no problems. So Iím assuming itís just the electrical portion of the starter. That said the spring back from start to on feels weak. So Iím wondering is the spring back a part of the electrical switch or the mechanical component of the ignition. Hoping I donít need to replace the expensive bit!
proporsche 11-20-2020 07:54 AM
yes just get the electrical portion ..It is a little pitta to do but doable;-)there is big load spring in the el.portion ....
Yup you got it ,today only 4 Celsius;-)
Been many times in Carlsbad, on the nice beaches there;-)
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
