-   -   remove cruise control servo on 86 (http://forums.pelicanparts.com/porsche-911-technical-forum/1078650-remove-cruise-control-servo-86-a.html)
alexandervdr 11-20-2020 08:40 AM
I want to take out the servo for checking.
The Bentley manual writes 'remove servo mounting screws', but don't show them on the pictures.
Anyone has a drawing/picture where those screws are?
Thanks!
GH85Carrera 11-20-2020 11:40 AM
As I remember once you remove the blower fan for the heater they are easy to see and remove. I took mine out when I replaced the bowden cable. It was a pretty easy thing to remove and install. As to the specifics, sorry it was too long ago that I did it. I bet if you search on this site you will find some photos of it.
stevie 77 930 11-20-2020 12:14 PM
There is a 8mm bolt on the back side of the servo that mounts to the bracket. Use a 13mm wrench to get back there.
http://forums.pelicanparts.com/uploa...1605903269.png
john walker's workshop 11-20-2020 03:44 PM
10mm ratcheting box end.
alexandervdr 11-20-2020 07:49 PM
with a nut a the back (#11 on the drawing above), the perspective of putting it back on seems challenging?
I have not looked yet in detail in the car to locate bolt #13 ( I am currently in my week-end residence away from the car), but is that one easier to get at?
Uwon 11-21-2020 03:35 AM
Don’t mean to hijack this thread, but where do hoses #15, 40 and 41 go?
TIA
GH85Carrera 11-21-2020 06:35 AM
I thought it was very simple. Start the nut with your fingers, tighten with socket. It is a simple task.
alexandervdr 11-21-2020 11:46 AM
thanks for the reassurance ;) Will work on it next week
