Window railing / regulator
My 1978 manual drivers side window regulator finally gave out. The " two arm" type is no longer available so I had to purchase the available unit that I now find out does not match my current railing on the bottom of the glass ( different rollers setup and slot). I have purchase the new / matching railing. The question is how do you remove the old bottom railing from the window glass ? without breaking the glass? The one body shop I reached out for help was not helpful - they were scared to break the window.
https://youtu.be/n8l-7NgGh0A
I found this video helpful when removing mine. Sent from my SM-G955F using Tapatalk |
thanks, this is helpful
[emoji106] once you get yours back in, I'd be keen on any tips/tricks from your experience please!
| All times are GMT -8. The time now is 10:29 PM. |
