944s4me's Avatar
Weight of Aluminum front cross member
Does anyone have an aluminum front cross member they could weigh and let me know the weight?
I'm assembling an older car that has the older steel crossmember, just wondering about weight savings?
Old 11-20-2020, 05:16 AM
Registered Minimalist
75 911s's Avatar
I just weighed mine for you. 4lbs 10 oz Scale is +- 3oz accurate It should be noted that I powdercoated mine clear. So likely weighs about 4lbs in the raw.
What does the steel x member weigh?
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 11-20-2020, 05:49 AM
kaputtrepariert's Avatar
Seems like around 9.5lbs: Weight savings by using and aluminum cross member on early car?
Old 11-24-2020, 02:05 AM
The 9 Store
I was always told 7lb weight savings but never measured myself. It's low on the front so not as important as other parts.
All used parts sold as is.
Old 11-24-2020, 03:13 PM
AutoBahned
RWebb's Avatar
6.6 lbs. less than the steel piece
above is for the cast Al - if someone wants to send me a forged Al RS crossbar then I'll weigh it and test it...
Old 11-24-2020, 03:29 PM
I have one here freshLY cleaned at work last week , but cannot find my fishing scales to weigh it
Old 11-24-2020, 08:00 PM
