What will remove wheel weight glue?
I've ended up with several spots on my rims that have the paper/glue backing left after the wheel was rebalanced. I've tried soaking the spots in Simple Green but this doesn't work. It appears the only solution is to scrape it off, but I don't want to damage the finish. Is there a product that will disolve this glue backing without harming the finish?
I've had good success with GooGone (http://www.googone.com/) or a little paint thinner on a soft cloth.
A J Burns '07 Guards Red Carerra 4S 911 Coupe w/Aerokit '86 Iris Blue Carerra 911 Coupe (given to my son) '63 Morgan Tiger Cub w/original Atomic 4 |
Googone or WD-40 works well.
Do a Search!!!! It will save you time typing as it was covered last week.
Neil '73 911S targa |
PPG Acryli-Clean from your local auto paint store. It's great for everything (adheasive/tar/wax removal, paint prep, etc.), and is safe to use on most finishes.
Information Junky
heat-gun, low setting.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Acetone, B-12 Chemtool, laquer thinner ...
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
One product is all you need, and it will not hurt your finish, 3M, 3M and more 3M...Check this thread out.. Wheel weight remains
Jorge (Targa Dude) |
If chemicals don't work, scrape it
I used a razor blade scraper. I used extra caution to ensure I didn't dig the corners of the blade into the rim. Came off without any problems or scratches.
If the chemicals don't work, give it a go. Gordo
Don "Gordo" Gordon '83 911SC Targa |
I use the 3M adhesive remover to clean the old tape off my Fuchs after having them rebalanced or tires changed. The 3M works like magic and so far has done absolutely no harm to my wheels.
Good Luck! Fred Cook '80 911SC coupe |
If your wheels are clearcoated (aluminum or painted) brakeclean will work just fine and will not harm the finish at all. I worked in a tire shop and a detail shop years ago and that's all we used for tire weights, bumper stickers, dealer decals, etc. Works to remove dang near any goo, stickum, grease, etc., as long as it's not on krylon or most other poof can paints. I would test on an inconspicuous place if you're not sure what kind of paint it is. The other products by 3m, etc, work very well too, but you should always have brakeclean around.
__________________ Clay '80 SC coupe |
