47silver's Avatar
beware of Beru Plug Connectors
i installed a new set of Beru connectors.
about 2 months ago i replaced the spark plugs.
when i reinstalled the plugs i had a miss.
when i investigated in found that one of the beru plug connectors came apart and the resistors in the connector were laying inside the cylinder head. I was able to retrieve them with a magnet and scope. i pulled the wires and replaced with the old porsche ceramic. and forgot about the Beru.
The otehr day i replaced one of the porsche with a Beru and when i pulled off the wire again the connector came apart. Luckily the resistors did not fall out.
the pictures show the connector, and boroscope screen shot of the plug with parts of the connector still on the spark plug
I was lucky as the resistors could have fallen into the plug hole if i did not notice.
garbage .
1975 911S Targa
Silver Anniversary Edition
Old 11-20-2019, 01:30 PM
Wow, disappointing.
Thanks for posting to let others know
Old 11-20-2019, 04:13 PM
Functionista
manbridge 74's Avatar
I’d rather install an old set found in the back of the shop than the newer stuff. Looks the same but not constructed like the original sets, at least for today’s aftermarket wires.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 11-20-2019, 04:58 PM
Originally Posted by lsf911 View Post
Wow, disappointing.
I had connector failure at the dizzy with my new Beru wires right off the get go. Very disappointing and expensive. I replaced with Clewitt
Bill
Old 11-20-2019, 06:02 PM
Bill
I has this exact same issue with a brand new set of Beru. Bought a set of Clewett leads and haven’t looked back. Awesome product.
Old 11-20-2019, 06:04 PM
I'm good with tools.
AG81's Avatar
Just replaced my set with new Beru...... zero issues....so far. Will be paying very close attention.
Thanks all.
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 11-21-2019, 08:41 AM
47silver's Avatar
they work fine
the new ones worked fine but when you remove them they come apart, i pried straight up usig one hand and they still come apart
poor design or maybe they are built for one use and throw away.
there is a post on here about restoring the old ones and removing the resistors so that would be what i would recommend
has anyone any experience with the german made ones that are supposed to be correct?
1975 911S Targa
Old 11-21-2019, 12:17 PM
Still here
pmax's Avatar
Counterfeit perhaps ? Where did you buy them from ?
Old 11-21-2019, 02:04 PM
(man/dude)
Jonny042's Avatar
I recently bought a set of Beru and they were missing the guts from one connector, the knurled brass socket that receives the plug was loose in the box! And no other resistors or parts so who knows.
I sent them back for another set and they seem ok, after reading this post I tried removing and replacing them, thankfully no issues. They have a nice positive "click" onto the plug, but then that could be the problem. I plan to test them with the ohmeter before firing up the motor.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 11-21-2019, 03:21 PM
47silver's Avatar
i bought them last year so will have to check where i bought them. they came in a beru box that looks authentic.
Old 11-21-2019, 05:45 PM
Functionista
I have recently installed one Beru set from SSF for a customer but no issues noted yet. The wires from Porsche are crazy expensive. Some time around 1986-87 they bumped up the juice to 30 kilovolts from like 20KV previous and this IMO makes life tougher on these wires.
Jeff
74 911, #3
Old 11-21-2019, 08:32 PM
(man/dude)
Jonny042's Avatar
I played around a bit more with these (easier to torture them to failure now than 6 months from now when I can't return them. So far, so good. However, a little trick that may help..... first, here is the bit that will/can/may pop out of the plug connector :
I tried popping this on and off a brand new NGK plug and found that it was not terribly easy to do. I tried a tiny bit of moly assembly paste on the tip of the plug and it seemed to help a bit, but what really helped the most was to give the plug connector a bit of a twist while pulling it off the plug. This reduced the effort considerably when I pulled the wires off the plugs and should prevent the wires from coming apart
One other thing I noticed was the tip of the plug seems to be very soft aluminum. I wonder if the spring clip wire isn't forming a groove in the soft aluminum and making it extra difficult to remove the wires and consequently causing them to come apart?
Old 11-22-2019, 10:57 AM
Troll Hunter
This just worries me. I JUST got my Beru set delivered and paid $100 for them. WTH? Do I install or return them? Geez...
1978 SC Coupe, Gris Argent Metallic Silver
1988 FJ62 Blue/Gray
2020 M2 CS
Old 11-22-2019, 04:53 PM
Mahler9th's Avatar
I have been hearing more and more stories of supply chain polution/counterfeiting. One that comes to mind is a story I heard from a shop owner about Behr expansion tanks in a BMW application.
I don't usually care where something is made. I care how something is made.
It seem advancements in technology and logistics may create a growing challenge with fakes.
Not saying that this is the case here, but I wonder about it.
I have been involved in many cost-reduction efforts, including sourcing from emerging areas.
I feel that counterfeiting is different.
Mike
PCA Golden Gate Region
Porsche Racing Club #4
BMWCCA
NASA
Old 11-22-2019, 06:56 PM
Functionista
I would fully check them out by plugging a spark plug in an out a few times. Make sure ends are on well, maybe ohm them for kicks. Be gentle on install and use a dot of dialectic grease on end of plugs. Probably not that big of a deal as maybe Beru tightened up on their methods and previous issues were part of a certain batch.
Jeff
74 911, #3
Old 11-22-2019, 07:01 PM
(man/dude)
Jonny042's Avatar
Just an update on this - Beru plug wires are absolute f$%#*&^@ing grabage. Don't bother.
Started to pull may plugs to inspect them after fireup and 2 out of three on the left side fell apart, even after twisting them to remove them. Tomorrow I'll be fishing around in the general vicinity of the #2 plug with an inspection camera looking for the remains so they can't fall in the plug hole and wreck my new motor.
So unhappy about this....
Old 04-29-2020, 05:36 PM
I had the same outcome on a 67 911 I was working on . It took me 4 hours to get the 3 faulty plug wire debris out of the plug area . Sticky substance in a wire and a mirror , got them after total frustration
Ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 04-29-2020, 08:05 PM
I've had problems with the Beru connectors for my 87 as well. One tore apart while trying to remove it from the distributor cap. Originally posted in Carrera Spark Plug Wires?, Posts 94 and 95.
Originally Posted by HaroldMHedge View Post
Bringing this back to life since it concerns the Carrera Spark Plug Wires.
While working on my 87 Carrera today one of the distributor plug wire connectors came loose. It does not look like the connection shown in Post 83 above.
Originally Posted by RichHawk View Post
Resurrecting this thread from the grave:
(Mark are you still making these wires?)
Two details were never clearly answered, So I under took it to answer them myself.
1) Are the 1987 Carrera plug wire ends at the dizzy Beru "M3" screw terminals? YES definitively. Here are pics from my all original 1987 wires:
Second was what length do the 1987 Carrera wires need to be...…….
This is a replacement Beru plug wire set. The spark plug end of the wires have the threaded connector shown above.
Has anyone else seen this connection and what do you think is the best way to reconnect it?
Looked more closely in the boot and found more of the fitting.
The connection seems to be screw on at the cable and press fit to make the 90 degrees to the distributor cap.
Old 04-29-2020, 09:57 PM
(man/dude)
Jonny042's Avatar
Ian
Yeah, I know what I'll be spending my afternoon doing........ not to mention trying to find an alternative.
I'm wondering if the Beru replacements for the plug ends (part #90160930900) are any better than what comes in the kit. They are available separately.
Old 04-30-2020, 05:18 AM
47silver's Avatar
If you have a good shop vac, get a small diameter hose that fits in the sparkplug recess and attach it to lthe shop vac i put a coffee filter on the large end taped the smaller hose to it and was able to vacuum out the parts and catch them with the coffee filter
Old 04-30-2020, 06:52 PM
