How straight is an aluminum cross member?
I bought one many years ago at a swap meet and I'm considering adding to my 72 while the suspension is out for a refresh. However, upon inspection, it appears to have a bend. Vertically it's level. The rear is flat but the front is a bit off.
As the photos show, the passenger side sits more flush than the drivers. I can't see any obvious damage or major nicks, but it looks to have a "bow" to it. How true are they?
Thanks,
Tinker
Old 11-25-2020, 01:22 PM
Registered Minimalist
75 911s's Avatar
FWIW mine has a bow in it as well.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 11-25-2020, 01:50 PM
914-6Werkshop
Not uncommon. Especially if the car has hit a curb. Lots of right side struts are bent for the same reason.
All used parts sold as is.
Old 11-25-2020, 02:09 PM
Thanks guys. My concern was aligning the thing if it was too far out of wack. That does not appear to be a problem?
Old 11-25-2020, 02:30 PM
That doesnt seem like a good indicator of straightness. Could just be the way it was cast. You need to measure off the machined surfaces and holes. use a 4' level as a straight edge get the center holes the same then you can measure to the big holes if its bent front to back and up or down.
Old 11-25-2020, 02:44 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
