Guest
Posts: n/a
HELP! I did a search and didn't find the torque value I need.
I need the torque value for the castle nut on top of the ball end (hub end) of the tie rod. My Bently manual says 184 ft. lbs. Is this correct? It sounds way high. The car is an SC. |
Ted, I believe the 184 ft lb is for the bottom nut for the ball joints, I seen 33 ft-lbs for the tie rod casle nut as per page 157 of Aug 2004 Excellence Mag. Rebuilding Front End tech article, Jerry
Guest
Posts: n/a
Thank you GMR911.
I just went back and reallized I was loooking at the wrong diagram. That nut wouldn't have made it to 187 ft lbs. Thanks again |
Virginia Rocks!
Ted, who's SC?
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
Glad I could help
