Converting 911SC doors back to stock from RS --help!
Hi folks, I recently acquired a '79 911SC. It came with the passenger door nicely converted to RS panels, the driver's door with no cards at all. The window felts are rotten as are the door seals, but the locks sort of work and the electric windows sort of work. So I am planning to restore the doors back to stock. The car came with *some* of the original parts (I know the pockets are the wrong color, but I can fix that.
I'd love some guidance on what parts I'll need to go all the way back to stock. What pullrods, plugs, screws, bolts, etc will be needed. I have tried squinting at the parts diagrams on the various parts websites, but I am quickly overwhelmed by the task of determining the difference in parts. Can you help me with some quick thoughts/wisdom on the things I'll most likely need? Thanks in advance!
1979 cashmere beige 911SC Coupe
1980 911SC Targa (sold)
1982 911SC Coupe (sold)
1966 912 Coupe (sold)
1975 914 1.8 Plaid Seats (sold)
Old 04-04-2020, 04:41 PM
Recently Disbanded
juanbenae's Avatar
your new pieces are very nice and I can see why you want to use them. your task is a tall one with what you've described you need in the way of linkage n fasteners.
the bently includes a pretty good image of all the fastener locations for the cards and pockets.
I would suggest a want to buy add in the classifieds for all the fasteners, finish washers and door mechanism linkage. many racecar builds end up with excess stuff and you might score a full set in a baggy.
Old 04-04-2020, 04:56 PM
I would source the factory PET. It gives the size and quantity of fasteners. Rob
Old 04-04-2020, 05:23 PM
(man/dude)
Jonny042's Avatar
The good news is all the bits and bobs you need should be commonly available, since so many people do the RS panel conversion to their cars.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 04-04-2020, 05:45 PM
It seems you have most of the parts to do it. The hardware needed you can see it in the PET.
Here the PET pages where the door parts are shown. The PET is available at the Porsche web page.
Old 04-04-2020, 06:24 PM
Old 04-04-2020, 06:32 PM
Thanks to all for those responses. Sorry for taking so long to respond. Not much is missing, but I'll post a wanted ad. In fact, I have two nice RS panels I may offer in trade.
Old 04-06-2020, 11:42 AM
7783911's Avatar
PM sent
Old 12-01-2020, 03:11 AM
It looks like you have most everything you need. I just did this on my '87 with RS panels and went back to stock (ish.)
There are 5 square anchors in the door that hold the pocket, as well as 3 inserts for the door for clips. You will probably need a few lock rod clips (one for the pivot point of the handle on door, and one for the inner handle)
The pockets are screwed on, there is one block at the back upper corner that get's screwed to one of the square anchors, and a center support for the lid.
The felt and rubber you need on the inside is push on as soon as you remove the top rail.
All of this is readily available.
Old 12-01-2020, 08:39 AM
