Len 911's Avatar
Front control arm bushings short
I have an 85 911 and order Elephant racing bushings. I do not have the originals..Are these the correct length? They do not go all the way through. They are shorter then the brackets.
Old 11-13-2019, 06:22 AM
(man/dude)
Jonny042's Avatar
They will elongate during the install process. When you order genuine Porsche bushings they look the same.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 11-13-2019, 07:29 AM
Len 911's Avatar
Thank you..I went home found the original ones...they are the same length...
Old 11-13-2019, 09:58 AM
Len 911's Avatar
All is good..just installed the Elephant Racing bushings went on great..
Old 11-13-2019, 06:32 PM
(man/dude)
Jonny042's Avatar
Good stuff!
Did you use their install tools?
Old 11-13-2019, 06:53 PM
Len 911's Avatar
Yes ..very easy with the tool
Old 11-14-2019, 04:06 AM
GG Allin's Avatar
I suppose, but what clamp are people using?
I bought a 3/4" pipe clamp from Harbor Freight. Great tool for $12, but not up to the task of pressing in these bushings. I did one side last night, not doing the other side until I have something heavier duty.
Also, where are you guys getting your angles from to set the front and rear mounts?
1988 911 - 3.6
1999 SL500 - Gone
1995 M3 - LS2 - Gone
1993 RS America - Gone
Old 12-02-2020, 07:36 AM
Len 911's Avatar
Put liquid soap on the bushings and use the bushing install tool from Elephant Racing. In the instructions it says the angles for the bushings. You can also look up the video on YouTube for clarification
Old 12-02-2020, 07:48 AM
GG Allin's Avatar
I used soap, I used the tools that came with the Elephant bushings. What I need is a bigger clamp.
The instructions on the Elephant website only show one set of angles. I'm wondering if there is anything out there that would account for various degrees of lowering.
1988 911 - 3.6
1999 SL500 - Gone
Old 12-02-2020, 07:56 AM
donagain1's Avatar
No need for clamps, search for the thread posted by "drola", he's got photos of using a threaded rod, and it works like a champ for not much money...
Don
Don
Rocklin, CA
-85 Carrera
Old 12-02-2020, 08:37 AM
GG Allin's Avatar
Don
I've seen videos where people used threaded rods, problem is my control are are capped at the leading edge. I don't think the caps are removable. If they are, I'd rather not due to fresh powder coat, don't want to muck it up.
1988 911 - 3.6
1999 SL500 - Gone
Old 12-02-2020, 08:54 AM
Kraftwerk's Avatar
Large pipe clamp worked for me actually need a pretty specific size clamp, which really should be specified in the directions. Notice the Elephant video-instructions are super -old, but still, information does not get old but the clamp used is a super-enviable NLA piece. My clamp bent ( user error!) so
I ended up using 'the door way method':
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 12-02-2020, 10:44 AM
gtc gtc is offline
abides.
gtc's Avatar
I just used a dead blow hammer and gave the Elephant installation tools a few good whacks. Worked pretty easily. Probably not a method that is endorsed by Elephant, though.
Graham
1984 Carrera Targa
Old 12-02-2020, 10:49 AM
Kraftwerk's Avatar
This is what I call "The Door -Way Method" I used a jack (out of desperation) when all my clamps crapped out.. it works just as well, if not better ...and more people have access to a solid doorway and a scissors-jack than a huge bar-clamp, right?
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 12-02-2020, 10:59 AM
Kraftwerk's Avatar
Here you see a rather unhappy bar-clamp. It's the most easily-available-type of clamp that some might even have already in their tool-shop, here it is super-stressed. a Pipe clamp works much better, the kind which uses they type of pipe used for gas-line, but mine was not co-operating that day, so door way it was....
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 12-02-2020, 11:06 AM
GG Allin's Avatar
I just picked up a 1/2 inch (I hope that's thick enough) threaded rod, 3'. A bunch of washers and a couple nuts. I'm going to go this route for the other side. Hopefully it works. I also bought a 1/2 inch acorn nut to use to try and tap out the end cap without damaging it.
It does take a ridiculous amount of force to press these bushings in.
1988 911 - 3.6
1999 SL500 - Gone
Old 12-02-2020, 11:46 AM
GG Allin's Avatar
I'm starting to think that 1/2 rod is going to buckle. In Drola's thread he used 5/8. The hardware store I went to did not have 5/8.
1988 911 - 3.6
1999 SL500 - Gone
Old 12-02-2020, 12:17 PM
Len 911's Avatar
This is what I used and had no problems. Just pick up a piece of black pipe from home depot and return it when done..
Old 12-02-2020, 03:31 PM
GG Allin's Avatar
The threaded rod is definitely the easier way to go.
1988 911 - 3.6
1999 SL500 - Gone
Old 12-02-2020, 06:31 PM
That's NYC thinking right there!
Old 12-06-2020, 07:58 AM
