-   -   Remove and replace EGR light- but with what? (http://forums.pelicanparts.com/porsche-911-technical-forum/1079917-remove-replace-egr-light-but-what.html)
Showdown 12-05-2020 06:00 AM
The EGR system on my 77S is inoperable but the light is still in the dash. I don’t really care that it’s there but if I could put something useful there that would be better.
Thus far I haven’t been able to think of anything to put there... any ideas?
I know this is super unimportant but the car is at the shop and I’m bored...🤷*♂️
fanaudical 12-05-2020 07:02 AM
I have the same issue in my '75.
I had added an external cooler and fan; had considered putting in a light to indicate when the fan was running. Used a lighted switch instead. Some other things I had considered (and haven't done anything yet):
Pushbutton for hidden garage door opener? (Not really in a useful spot.)
Indicator that fog lights are on? Or that radio antenna is up (if using an electric antenna)?
Extra oil-pressure or voltage warning light? Add a temp switch and have a oil temp too hot light?
Connect in parallel to the CIS cold start valve so that I know when it's on?
Put in a novelty "Pilot Ejected" light?
Add AFR monitoring and add an indicator light for when mixture goes too lean?
Anyway, my EGR light is still in the dash and unlit...
gomezoneill 12-05-2020 08:05 AM
Rev limiter light.
rwest 12-05-2020 08:08 AM
I put an alarm blinker in mine.
blucille 12-05-2020 09:10 AM
USB charger?
SiberianDVM 12-05-2020 02:23 PM
I put a small digital LED voltmeter in mine.
Reiver 12-05-2020 08:00 PM
How about a pic of that....
fanaudical 12-05-2020 08:48 PM
Rev limiter light is a good one - hadn't thought of that...
SiberianDVM 12-06-2020 05:30 AM
http://forums.pelicanparts.com/porsche-911-technical-forum/1074674-what-went-hole-dash.html
#20 on this thread
