Help with wiring rear wiper - 3.2 Carrera
Hi Pelicans,
Been trying to get my car back to the factory options and realized it had a rear wiper. When it was removed they disconnected the wire harness and must have thrown it out. I have figured out from other posts the wires that attach to the motor and I found the two connectors on the other end sitting in my engine bay. I just need to know where wire with the circle goes ( looks like a ground) and then the solid red wire with the straight connector?
Thanks for any help, Brian
Old 06-27-2022, 02:22 PM
Brown Wire with the circle connector would typically go to ground
Old 06-27-2022, 03:40 PM
I Wonder
mgro1959's Avatar
Circle connector is ground and I think it connects to the ground bolt by cdi box on inner fender panel and straight connector connects to the fuse terminal in the back left of engine compartment. I believe there are three fuses in that box. Thanks Rob.
Old 06-28-2022, 03:00 AM
Thank you for the info.
Old 06-28-2022, 05:57 AM
