Pad replacement ...glue on brake Sensor? 85 911
It there a thread on glue on brake sensors? I wanted to purchase the TVR pads but they dont make REAR pads... would like to match front and rear. I dont want to buy Porsche Pads due to the price, using other pads I would need to change sensors to new Glued on Sensors, no longer can I use the notch, clip in type....all new to me! Not sure how that works...
'85 911
Old 12-09-2020, 07:10 AM
cycling has-been
bkreigsr's Avatar
Can't tell you what adhesive to use.
On my 85, I never relied on the sensors to tell me when the pads are low.
I disconnected them by clipping the wires in the wheel well, tracing them to the frunk, and reconnected them to each other in the frunk - out of the way.
Pads are most efficient when they are more than 1/4 inch thick. Less than that, they heat up quicker, and transfer that heat to the rotors and calipers. Not good.
Bill K
Old 12-09-2020, 09:47 AM
Tags
brake pads , glue , sensors
