Central heat controller inop
The rotary dial under the parking brake for the heat is not turning on the footwell fans. Fuse is good. Not sure which relay.
Potential clue. Heat worked fine before engine was removed, rebuilt, and replaced. Is there by any chance a wire or plug in the engine compartment that was not reconnected? 1986 930. Thanks. |
Certainly possible. The fan on the left side by the cruise control has to be plugged in the get the footwell blowers to work.
| All times are GMT -8. The time now is 10:11 AM. |
