3.0 to 3.5 Litre Rebuild with ITBs, Motec, EFI
pls delete this thread..
TOO Much time on my hand's comes to mind.
beautiful job..but...looking at your clutch arm ..it does not seams it is fully pulled back for correct adjustment
Ivan |
Anyone know how to change the title??
Hi Mike somehow i do not think so, the clutch arm seems way towards the front of the car ...it should be strait not in an angle look here..
http://forums.pelicanparts.com/porsche-911-technical-forum/621701-915-clutch-arm-spring-arm-assembly-install.html Did you when you install and hooked the cable pull back with a screwdriver on the arm to load the Omega spring?? like this?? https://www.youtube.com/watch?v=vNdMp_W-cmY |
Sorry, I deleted this to start a new thread.. for some reason, I wasnt able to change the title of this thread from "Delete"..
Sorry about that. |
Mike, do not worry to much at least it stands out;-)
ivan |
Mike did you delete those pictures??it was all looking very nice,why?
Ivan |
| All times are GMT -8. The time now is 02:38 AM. |
