Valve Guide drill bit source needed
I used to get them from Baum tools. Jerry Woods Had them for a while IIRC. Getting a batch made from a tooling outfit isn't cheap. Any idea who still stocks them?
Pilot end is 9mm to fit the guide bore. Drill bit OD is 11.80mm/.464". I'm down to my last one. http://forums.pelicanparts.com/uploa...1608327882.JPG http://forums.pelicanparts.com/uploa...1608327882.JPG |
Could you make a few step drills using your metal lathe, a toolpost grinder (or even a Dremel mounted to the toolpost) and the correct-size drill bits (.464" O.D.)?
Nix |
Apologies John- not much data out there. Using the Wayback Machine, I was able to find the old listing from the Baum Tools online catalog for May of 2005. Below is the main image clip. The pop-out was not available, but it references Tool #87 as well. Hopefully, this helps in the search...
Link: https://web.archive.org/web/20050507123638/http://tools.baumtools.com/index.jsp?menu=por&newIndex=3&index=11&make=por&mo del=&part_number=&primary_section=&secondary_secti on=&tool_use= http://forums.pelicanparts.com/uploa...1608345941.jpg |
Baum said they didn't have them, but I'll try calling with the number 86B.
Looks like a modified twist drill bit. A good machinist with a grinding attachment on a lathe and the proper sized collet could knock out a batch reasonably quickly. Mc Master will have the core bit.
Don't have a tool post grinder. Rather buy several. Already priced getting some made and it's out of hand. Must be some out there for sale.
John,
I will poke around as we would buy a bunch as well. |
can you go to .492 OD?
https://www.cylinderheadsupply.com/dcmkwikway.html item 7211 is sorta kinda close all you're doing is drilling out the old guide and leaving a shoulder so you can pound it out? |
maybe another
https://www.mcmaster.com/29525A56/ I don't have the stem diameter so I looked at my BMW motorcycle book and the airheads use 8mm stems. |
John - I suspect there are many Seattle-area shops making custom machining / cutting tools for the local aerospace industry. I did a quick Google search and came up with this one:
Cutting Tool Control, Inc Cutting Tool Control, Inc Cutting Tool Control, Inc I'm sure there are others. If you know somebody local in the machine-shop business, they may have a favorite tool grinding service they use. |
Hey Jeff you may want to reach out to Modern Engineering on River Road, they may be able to help. Cheers, Andrew |
Cutting tool control did the last batch, but new people in there now that are less than cooperative.
Swift tool wants $149 for one and $84 each for six. Gotta be a better deal. |
They were ready made and available several years ago, just for drilling out 911 guides, so there should be a source from the past that provided them.
Since this has the same layout as a drill piloted counter bore, what stops you from sharpening the current ones you have?
The drill point is pretty standard and the counter bore portion can be sharpened on a tool grinder. Same operation as tip sharpening an endmill. |
this should work and I doubt you will beat the price |
But I need a 9mm pilot. 8mm works for a 993. I have those.
| All times are GMT -8. The time now is 06:19 AM. |
