Removing ac 83sc help please :)
https://share.icloud.com/photos/0uLl...yJfcflSxcjr-tgNot sure what this is but the rear wheelwell condenser runs into it.
It’s in the drive side rear front of the well. Can it come out or is it needed for another system in the car? It’s not the drier that would be in the front right? |
<a href="https://ibb.co/Q9HcBZD"><img src="https://i.ibb.co/xhgsvyF/422-E324-B-9631-4-FF0-A46-F-7-DFCC048133-B.jpg" alt="422-E324-B-9631-4-FF0-A46-F-7-DFCC048133-B" border="0"></a><br /><a target='_blank' href='https://dedupelist.com/'>delete duplicate keywords</a><br />http://forums.pelicanparts.com/ht
That is aftermarket so can be removed....
It is the reciever dryer, not sure what the smaller wires? Hoses? Are for so be careful removing. Yes it goes too.
Thank you, other wires went to it and then back to a mess in the rear fuse panel area, couple of relays that weren't hooked to anything. Glad its all gone now :) |
The switch wiring was probably for a high low AC pressure switch.
| All times are GMT -8. The time now is 05:23 PM. |
