Question e-brake cable help needed
I'm attempting to get the trailing arms off my 73. Got everything loose with one exception....the e-brake cable.
I can't get the castellated nut off, it is rusted to hte cable. Yes, the cotter pin is out. What can I do to keep thecable from spinning as I try to loosed the nut?
Fritz
1987 944S
1973 911E
Old 04-27-2003, 10:30 AM
Duh - found the hex portion of the cable, problem solved (except for the one side that has a broken cable, but I consider that a new problem).
Fritz
1987 944S
1973 911E
Old 04-27-2003, 12:03 PM
