Easily Confused
dtxscott's Avatar
Rear Brake Piston Pitting
I'm in the midst of rebuilding the stock Ate calipers on my '89 Targa. All the components look really good and have cleaned up nicely. However, the impression on one of the rear pistons seems really odd.
It seems too symmetrical to be rust pitting. Almost looks like a mfg defect or a latent defect from a repair.
Anybody seen this before?
Scott C.
'08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65
Old 12-22-2020, 03:50 PM
djpateman's Avatar
That looks like it was struck with the end of a bolt. It does appear to my eye to have a risk of fluid leaking if it sat on the seal; then you could lose braking action. I would try and find a replacement. It may work okay for a while if the pads were full thickness.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 12-22-2020, 04:48 PM
Host sells them
Old 12-23-2020, 06:25 AM
Easily Confused
dtxscott's Avatar
Thanks for the comments. It is a weird impression for sure and I did have some minor leaking on that caliper.
Scott C.
Old 12-23-2020, 08:04 AM
Easily Confused
dtxscott's Avatar
Originally Posted by Dpmulvan View Post
Host sells them
I did see the 48mm front pistons. This is a 38mm rear and haven't found it. If you know where it is located, I'd be grateful for the pointer.
Scott C.
Old 12-23-2020, 08:09 AM
Give PMB a call: https://www.pmbperformance.com/catalog.html
Old 12-23-2020, 08:53 AM
Easily Confused
dtxscott's Avatar
Originally Posted by Locker537 View Post
Great suggestion. Looks like they have 38mm pistons
Scott C.
Old 12-23-2020, 09:43 AM
Easily Confused
dtxscott's Avatar
For completeness and accuracy.... The rear pistons are 42mm on the 84-89 Carreras. I mixed the sizes with the SCs. I didn't see the 42mm pistons on PMB's site
Here' is a link to the rear pistons at Sierra Madre: https://*********************.com/Rear-Brake-Caliper-Piston-42mm-911-84-89-p30549.html
The url is all one comprised of these words: Sierra Madre Collection
Scott C.
Old 12-24-2020, 06:49 AM
