Coil / Distributor Wiring
Question related to the wiring harness section photo below on my ‘72 2.4
I believe I have the wiring down but want to confirm. My main question is where the ground attaches to the distributor.
Here is what I believe:
- One braided ground end attaches to the coil mount.
- The green wire near that end attaches to the negative terminal of coil.
- The other braided ground end attaches to the distributor but I am not sure where?
- There is a black wire and a purple/black coming off as well. I believe both of these attach to the spade connection on the distributor (piggy back)?
Help is appreciated!
Old 12-29-2020, 11:20 AM
Old 12-29-2020, 11:21 AM
Actually I am now thinking the ground connects to the motor behind the distributor instead of to it?
Old 12-29-2020, 03:59 PM
On my 73 2.4 the second braided wire has always gone to ground on one of chain cover stud nuts.
Old 12-29-2020, 08:03 PM
Thanks, John. Appreciate the response!
Old 12-29-2020, 08:35 PM
E Sully's Avatar
The black, CDI C terminal, and bk/prpl, tach signal, piggy back on distributor.
I would check to see if that green wire is actually a faded blue from A terminal on the CDI to 15 on the coil. There is a green wire in the harness for Sportmatic oil temp. Porsche uses brown for grounds, not green as US does.
Here is a photo I found showing the coil ground is a short brown wire from the mounting stud along with the small shielded wire, with the ignition wire shields opposite side. I can't say where the distributor ground originally went.
Ed
1973.5 T
Old 12-30-2020, 07:09 AM
^thanks!
Old 12-30-2020, 08:20 AM
