Hi
Fuel Filter/Strainer
Can someone tell me how this filter (911-201-141-00) works within my fuel system?
I understand it screws into the bottom of the fuel tank but I don't understand how it filters or strains the fuel. How does this work with the fuel pump? Thank you. Larry 1984 911 3.2 ![]()
"A good sense of humor is the best thing to have in your toolbox when working on these cars." Quote by Charles Freeborn, Pelican. |
The strainer goes up into the fuel tank, where it seats into a boss that feeds the fuel pump. The filtered fuel comes out of those openings under the grey plastic collar near the brass nut. From there it goes to the fuel pump.
This thread showing the inside of a CIS fuel tank should help clear things up: CIS Gas Tank Mark
1979 911SC Targa |
Hi
Thank you. L
'73 911 T Targa
So, do I correctly imagine that the tank must be drained in order to inspect or change this strainer?
To do it safely, yes. Whatever fuel is left in the tank will drain out in a hurry when the strainer is removed. Probably easiest to remove the fuel sender unit and siphon from there.
Mark
1979 911SC Targa |
Enginerd
Fuel removal setup
Yes, this setup worked very well for me. The transfer pump was from HF (~$10 I think) then I added some tubing, hose clamps, and a $4 filter. Removed all the remaining fuel in my tank in under 10 minutes with no spillage. Made removing the tank and thus the filter very easy. I removed the tank for refurbishment, if you don't need to take the tank out then just remove the strainer from below. Easy peasy.
Dennis
1982 Guards Red 911SC, 1994 Riviera Blue RoW 993, 2020 British Racing Green Macan GTS Gone but not forgotten: 2017 GT Silver Turbo S, 2012 Guards Red 991.1 C2S, 2017 Carrera White Macan GTS IG: @pcar911fan Last edited by TxGerman; 01-05-2021 at 04:15 PM.. Reason: Update and format |
