Unhappy 86 911 hard start and idle surge
I recently replaced the cap/rotor and plugs for a tune up. Car runs great, went down for gas at BP, got gas, left and the car dies and will not start. Finally got it started after 15 minutes or so and it runs like crap. Now it's real hard to start and won't idle. I was thinking bad gas, so I drained the gas via the FP hose, cleaned the fuel screen(27mm allen acessed one) installed new fuel filter and it still is the same, so much for bad gas. It also smokes when it finally starts now just for 20-30 seconds, I think it's from cranking it so much before starting. Any suggestions?
86 951, some mods, nice daily driver.
86 911 targa, daily driver
90 Mitsubishi Eclipse GSX, 9.41@146.38--Race car.
97 Jeep Grand Cherokee, Tow-Rig
Old 04-28-2003, 04:20 AM
makaio's Avatar
Did you check all the connections, cap, rotor, plaugs, to see if something came loose? Make sure all connections are good, the rotor is seated properly, and the cap is on tight.
Old 04-28-2003, 01:11 PM
If one wire was bad would it cause this? I did double check the cap/rotor, seemed ok. Took car to C&G perf. today, hope for the best.
Old 04-28-2003, 05:59 PM
Fixed!! It was a bad FPR. Runs like new again.
Old 04-29-2003, 05:31 PM
makaio's Avatar
By FPR, do you mean fuel pump relay?
Old 04-29-2003, 06:40 PM
Matt
FPR = Fuel Pressure Regulator
Jerry M
'78 SC
Old 04-29-2003, 06:43 PM
Yes regulator, very odd, pull the vacuum line of and there was gas!
Old 04-29-2003, 06:53 PM
