Install window scrapers?
I have my new window scrapers (driver and passenger side), how do I remove the metal trim to remove the old scrapers?
Thanks.:) |
With the window down, use a very small flat-head screwdriver and lite pressure to pry up...just use alot of care and patience...also take care not to lose one of the positioning clips...ask me how I know...
:D |
if you talking about the external scrapers its very easy - as per coldbass - with the window down - pop them out from the inside as so not to damage paint - I just removed mine within the last week and if it was difficult I would have remembered!!!!!
The hard part is getting the scrapers in. The clips will stay put if you wrap the end with a piece of tape.
This was a tough job! Took me about 2 minutes, so that's about 1 minute for a normal person!;)
Window Scraper |
thanks...will try to pry em up and install the new scrapers today.
damn.....
the removal of the trim piece was quite easy...just pulled it up by hand. Installing the new rubber scraper...NOT EASY!!! This part sucks since I spent a good 30 min just installing the drivers side piece. |
I ordered a new scraper along with some other stuff yesterday from Pelican, I hope it's as easy as you guys say. I've replaced them on a 914 before with no problems. Sometimes doing the same job on as 911 is much, much more involved :)
Yeh Smitty. I found WD40 helpful in getting the rubber inplace.
Full strength Dawn Dishwashing detergent .... I know I was surprised also but it worked great.
Haasman |
Easy-peasy!
BEST! Doyle |
| All times are GMT -8. The time now is 04:22 PM. |
