Zinc plate case through bolts?
Having some parts plated and was wondering whether there are any potential negative impacts of having the case through bolts yellow or clear zinc plated?
Todd
1989 911 Targa |
zinc case bolts
All day long.
cycling has-been
Fred, please expand.
'All day long' on the zinc plating or 'all day long' on the negative effects? There is currently a 3.0 rebuild on the FS forum with zinc plating on the case bolts, and I'm wondering if this is a good thing or not. Thanks, Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
Zinc has minimal corrosion protection. If your going to have them electroplated to prevent them from rusting then have them done in either cad or zinc-nickel. If you get them electroplated please have them baked immediately after @ 400. Time in baking is dependent on the hardness of the bolts. Or go with stainless steel from ARP
THIS: stainless steel from ARP
how could the trough bolt get rusty?? What would be reason to zinc them design??you will never see them ..
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Do you guys who do zinc plating have a place to send it out to or do you use local places?
I believe the factory bolts were cadmium plated.
Based on my 30+ year old bolts, the only rusty regions were the exposed head and bare threads. I.e. cosmetic surface rust. Bare in mind they were also caked with oil leaking and dirt. The working threads and under-head fillets were clean and unrusted. Which means the cad plating was still doing its job. So there was no need to replace the bolts. If the body of the bolts are rusty, I would recommend replacing them. They have been compromised. Plating would only hide the damaged surface. Reinstalled after cleaning. 18,000 and 5 years later no issues. Last edited by VFR750; 01-08-2021 at 03:42 AM.. |
Case through bolts were originally black zinc phosphate which has minimal corrosion protection. If you replate them they must be baked. Yellow cadmium has better corrosion protection than zinc and less hydrogen embrittlement.
I used to do them in black phosphate, first pics but do them with Cerakote now. Yellow cadmium is a good solution but Cerakote looks correct and will last longer. ![]() ![]() Cerakote and yellow cadmium on the left ![]() ![]()
Tru6 Restoration & Design Last edited by Shaun @ Tru6; 01-08-2021 at 03:53 AM.. |
Diss Member
(Been looking at Cerakote for some other items and it looks bomb proof.)
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Applied correctly, Cerakote is only a little thicker than plating. Acorn nuts spin right on.
I have Cerakoted a lot of hardware, never an issue. Just did a set of A-arms in Cerakote. These torsion bar adjusters are "loose" if anything. I am strongly against powder coating and only use Cerakote. ![]()
Tru6 Restoration & Design |
cycling has-been
Shaun, not to get too far off track - but whats the up-charge for specifying Cerakote, if there is one ?
Bill K
[QUOTE=Shaun @ Tru6;11171896]Case through bolts were originally black zinc phosphate which has minimal corrosion protection. If you replate them they must be baked. Yellow cadmium has better corrosion protection than zinc and less hydrogen embrittlement.
I used to do them in black phosphate, first pics but do them with Cerakote now. Yellow cadmium is a good solution but Cerakote looks correct and will last longer. .................................................. ..................................... Would you explain to me ,i wonder ,how those through bolts can get rust on them if the are inside the engine case no oxygen only oil on them..thanx Ivan
Bill, Cerakote and yellow cadmium are both $10 per bolt.
so,is anybody here to tell me the reason to cover the trough bolts with zinc or anything???
Is it just to be pretty, i guess? Ivan
People do it for bling factor. The truth of the matter is that case bolts expand and contract which will allow some plating to flake. That flakes are truly dangerous as they can cause damage to bearing surfaces as well as clog oil passages. I just utilize through bolts raw and will sometimes have the acorn nuts and washers plated if the build calls for “bling”.
1973 Porsche 911 RS 1981 Porsche 931 Euro-Intercooled-GT 1984 Porsche 911 Euro Carrera widebody 1987 Porsche 924s Rallye Spec Instagram: @soyracer |
yup that is kinda my point..there is absolute no reason to do that to the bolts-nobody will ever see them again unless the next mechanic will love it...;-) the rest is design i got that..
Ivan
+1 for Soy.
