Upper valve cover warped
Hi,
After valve adjustment new oil and gaskets the car runs fantastic.
One thing I hoped to fix is minor leaks from the valve covers.
Now that everything is clean I realized the leaks are from the upper valve covers as the lower are upgraded turbo.
I noticed pitying on the surface and when put on flat surface the covers don’t sit flat.
The host sells nee oem for 475 usd each.
Can my old ones be grinned to flat?
1974 911 coupe 4 speed
Old 01-08-2021, 04:46 PM
Reiver
Reiver's Avatar
I've seen shops put the lowers on a supported glass surface (flat table) with fine sand paper and gently move the cover for/aft until an even surface shows by an even rub/contact trail .
I suspect it depends on the amount of pitting and uneven surface but worth a try aye.
De Oppresso Liber
Strength and Honor 5th Legion
Old 01-08-2021, 04:58 PM
get a long piece of sandpaper for a large belt sander lay it on a flat surface and sand away. check the head surfaces aswell. and the rocker shafts
Old 01-08-2021, 05:09 PM
As above. Did mine about 6 months ago. Used left over piece of smooth granite and used roll type sandpaper that hVe adhesive backing, I use this on my long sanding boards for body work. Amazon others sell it. I started with 120, 400 then 600.
Old 01-08-2021, 05:14 PM
Amazing intel.
Will try the sanding option.
Old 01-08-2021, 05:43 PM
While sanding use a figure 8 pattern so grooves don't develop.
Old 01-08-2021, 05:52 PM
Find some shop with a belt sander or you'll be rubbing it 'til the cows come home.
206 637 4071
Old 01-08-2021, 07:05 PM
Reiver
Reiver's Avatar
Had a cow in my yard this am....does this mean anything?
De Oppresso Liber
Old 01-08-2021, 07:15 PM
That is a tool.
Will look around.
Old 01-08-2021, 07:26 PM
Here's my suggestion: https://www.pelicanparts.com/More_Info/90110511511M350.htm?pn=901-105-115-11-M350&bt=Y&fs=0&SVSVSI=807
Old 01-09-2021, 08:04 AM
Rescuer of old cars
Arne2's Avatar
The upper covers on my '72 were not only warped and pitted, but also cracked. Check them carefully for cracks before resurfacing the ones you have.
I bought a pair of used covers on eBay that had been freshly resurfaced for about $175 or so.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 01-09-2021, 08:59 AM
Most machine shops have a surfacing table of some sort. My magnesium intake was warped and they flattened that in under 30 seconds.
Derrick
Old 01-09-2021, 09:05 AM
proporsche's Avatar
kava..why don`t you get good use set from the net less then couple hundred bucks...?
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 01-09-2021, 09:37 AM
