6 x 15 Fuch differences
I expect this will be easy for someone out there!
6 x 15 Fuchs - 911361020 (pre 73) & 911364020 (post 73 I assume). How are they different apart from # & is the offset different? Can the later wheels be fitted to a 69-73 narrow bodied 911? Thanks, |
Actually the wheels changed from the "deep-dish" style 6" to the falt style in 1972. Im pretty sure the actual offset is the same so they will be interchangable.
6x15 Same Offset
Early/DEEP 901.361.012.06 FLAT 911.361.020.00 Later/FLAT 911.361.020.10 Don't know date offhand |
The early versions of the 6 x 15 used a three prong attached center cap. The later version used a flanged ring attached center cap. Not interchangeable
Kiwi/Gary
I've got some early (deep) ones (presumably '69) and some late ones (presumably '75) at home. The latter are on the '75, the former are in a pile but were on the '69. If you wanted to borrow one of the later ones to check (they have 215/60/15s on them), then no problem. But as these guys point out, they will definitely fit. |
Thanks everyone,
Hi Cam - must see your car soon, Gary |
Yes! That would be cool Gary.
I better get it WOF'ed - too busy at work - its dragging on for weeks too. |
I had a pair of deep dish and flat style on F&R on 72, no difference in offset, both pair fit just fine.
Phil |
Freshly restored deep dish 6x15's - oooohhh aaahhhh ooohhh
http://forums.pelicanparts.com/uploads/Newfuchs31.JPG |
| All times are GMT -8. The time now is 11:48 PM. |
