OK, good progress to this point. Now the issue is getting this roll pin inserted. WTF? Got the assembly anchored well and I have a decent sight line to it but the damn thing doesn't want to go in. The wife suggested coconut oil with a grin but that won't help in this situation;). I guess using the old one is a no-no. Any tricks anyone can share?
http://forums.pelicanparts.com/uploa...1610819208.jpg |
I just did this a month ago. Inserted a pin punch from behind to make sure that everything was aligned. I then used a second pin punch that was slightly larger than the roll pin and hammered it in. It took me 30 minutes and was way less frustrating than the press of removing the roll pin which probably took over an hour of hammering.
I am not the most patient person in the world, so this was good for my personal development. The other good news is that putting everything back in is far easier than taking it out. I also replaced the clutch cable and got to take the car for a drive before MN became a snowy mess. What a difference and well worth the frustration. |
For putting the roll pin back in, lining up the backside well is important, lube up the pin with grease, then one good smack to get it started was all it took. All in all I spent maybe five minutes on it, so maybe I was just lucky.
When it's all assembled in hand it's interesting, because it turns into a mouse trap. With the pedal all the way up it stays put, but push it down just a little bit and the spring snaps it down with astounding force. http://forums.pelicanparts.com/uploa...1280180875.jpg |
is it possible to reverse the spring for the clutch pedal (cluster)? My mechanic refurbished the pedal cluster and the clutch pedal is a hard press going down. This leads me wonder if he reversed the spring to cause this problem. Anyone?
Thanks Bob |
Every little bit helps. |
Kachi - I did. It was a bear to get in but I finally got. Everything is assembled and the cluster is re-installed. I called it a night and will resume again tomorrow if the wife doesn't mind. I've been in the garage almost all weekend and loving every minute of it!
Last tough piece of the puzzle and any help would be appreciated. Cluster is back in place and the clutch clevis isn't even close to reaching the clutch arm. It's also a little askew making it even more difficult. I'm not sure what I could have done to make this happen. Any suggestions? I suppose I could follow the instructions on replacing your clutch cable to disconnect it so it can reach the clutch arm but won't I just be passing the problem off? If it doesn't reach now I can only assume I will have shifting problems? Losing confidence and unsure where to go from here? I come so far and I'm almost there, any ideas on where to go from here would really be appreciated. Thanks.
http://forums.pelicanparts.com/uploa...1610910342.jpg |
There is a remote chance that when you drove the devil pin in it was 180 degrees out of alignment with the clutch rod and arm flange. I came very close to making this mistake myself, it is easy to do. |
Don't ask me how I know! |
I'd replace the cable since you are there...it is as old as the worn out clutch arm.....and been thru as many repetitions.
I believe in retrospect that I hooked up my cable before bolting down the pedal cluster.
You may have to unbrace and unbolt. |
I also decided since I have to disconnect the clutch cable from the helper spring and the considering the condition of the original clevis pin and clutch arm, I should just go ahead and replace the clutch cable while I'm there. Both of which should arrive tomorrow. With any luck the clutch cable R and R will go smoother than the pedal cluster rebuild and I'll be back on the road by the end of the day Saturday! |
| All times are GMT -8. The time now is 10:25 AM. |
