Wanted to do this for some time. Here are the oil pressure my car reads. What do you think?
Cold Idle 3.8-4.0 Warm Idle 1.2 2000RPM 3.3 3000RPM 3.8-4.1 4000RPM 4.2 5000RPM 4.4 JG
1985.5 944 GTS |
Looks pretty much like mine.
Robert Stoll 83 911 SC 83 944 |
I've got 127,000 miles and no major rebuild I'm aware of. So you've got an '83 SC in the same shape. Are these good number or bad numbers and do they indicate anything? I'd love to find someone who recently did a rebuild and compare.
JG
1985.5 944 GTS |
I think they are fairly normal readings. I have about 20,000 more miles on mine. Still running strong. I have had it for about 2.5 yrs. Has been a real dependable car, although not a daily driver.
Thats weird. If we're talking about the Druck Press, I have an '84 with considerably higher readings. It has 178,000 miles with no major engine work done as far as I know. The mechanic just did a compression test and all checked out fine (I think the numbers where between 135-155). The Druck Press wasn't working for quite some time I was told (I bought the car a month ago) and I just fixed it a week ago (the wire under the shrink wrap came off the sending unit).
cold idle @ 3.5-4 warm idle @ 2.2-3.2 Whenever I check the gauge at speed it reads @4.2-4.9, although I'm usually at around 3k rpms. The temp gauge needle always stays just below the first SMALL (skinny) white line and in bad traffic it creeps up to just above the white line.
1984 Carrera Coupe |
Mine drops quickly as the RPM's drop. Drive it a little and then see where it settles at idle, it will probably drop below the figures you show. Now where's the post on the newly rebuilt engine?
JG Oh, and congratulations on the choice of car.
1985.5 944 GTS |
Unregistered
What kind of oil are you running and at what viscocity? that makes a big difference.
My owner's manual for a 1980 SC states: " with the engine at operating temperature (194 degrees f, 90 celcius) and an engine speed of 5000 rpm the oil pressure should be about 4.5 bar.......a drop in oil pressure at higher temperatures is normal. At idle speed, with the engine oil hot, it is permissible for the green control light to light up-this does not indicate any loss of engine performance. " Thicker oils will show higher oil temperatures, thin synthetic oil will show lower pressures in most cases. |
Castrol GTX 20-50
The 4.5 Bar @ 5000RPM sounds right on. I'm, more concerned at lower RPM and when Idling. I have a new set of cam oil lines to install and I purchased the newer adapters with the smaller orifice to provide increased oil pressure. I juts want to cover my bases before I install. JG
1985.5 944 GTS |
It doesn't drop that much. I use Valvoline 20/50 All Climate. I'd imagine that there's many a subtle differance from guage to guage as well.
Navin Johnson
are you guys using the oem oil pressure gauge?
check your gauge against a known mechanical gauge sometime. one of my engines shows 0 psi at 1000rpm (on the oem VDO gauge) when I hooked up a mechanical gauge i had 15 psi AT 1000RPM.
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
The rule of thumb is 1 bar or better for every 1000 rpm when the car is hot. So 3000 rpm should be 3 bar or better, 4000 rpm should make 4 bar or better, etc. At idle it doesn't really matter what the oil pressure is because the engine isn't working so it doesn't need oil pressure, and the guages aren't that accurate at those low pressures. Also, when the car is cold, the oil is thicker so oil pressures are higher - also not readings you should pay much attention to when evaluating an engine's health.
Hope that helps.
jasper 2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car. past: another 2002 996 and a 1978 SC with-webers-cams-etc. |
Does "better" mean that you can't have too high of an oil pressure reading?
1979 911 SC Targa http://www.pelicanparts.com/gallery/Mike_Kast |
I've sure never heard of too high oil pressure.
Too high an oil pressure can wash out bearings.
By too high...I mean very high....in the 100+ area. Oil flow is more important....a good high VOLUME oil pump is normally called for in very long life engines. And...the oil pressure relief valves can be checked for operation (and should be) whenever you change the oil (if only by checking the higher pressure relief by reving the engine when it is fairly cold). The pressure should rise quickly then stay at one point reguardless of revs (higher)...this shows the high press relief is working. Oil is the lifeblood of the engine....keep it cooled...keep it clean. Bob
Bob Hutson |
Crusty Conservative
Guys,
Before anyone gets panicked and tears their engine down, let's get a good hold on the numbers here. First of all, Druck means Pressure in German, so Druck Pressure is redundant usage.. The Druck gauges are in bar, 1 bar = 1 atmosphere at sea level, or about 14.7 psi I think the gauges labelled Pressure are all calibrated in PSI increments of 10 psi per line - NOT THE SAME THING as 1 bar!!! The rule of thumb, going way back to something writtten by BA in the good old days, was "about 10 psi per 1000 rpm" as a good minimum oil pressure for a warmed up 911 engine. The pressure should bypass at about 60 to 70 psi some where, if it is not, that's a problem too. So, to close 1 bar per 1000 rpm would be on the high side of expectations, not an average reading...
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) Last edited by silverc4s; 04-27-2003 at 04:34 PM.. |
I thought "Druck" meant "Oil"? Man, my German needs some help
Oil in German is OEL - that's on your oil level guage next to the temp guage.
With respect to guage labelling - I'm pretty sure the ol' DRUCK PRESS guage is incremented in bar. I can't see the germans using pounds per square inch since they don't really recognize pounds or inches as valid units of measure (we canadians don't either). My SC used to produce just over one increment per 1000 rpm of engine speed. Over time this dropped to just one increment per 1000 rpm.
