Kurt
924 Gauges and indicators in a 911?
Hi all,
How interchangeable are the gauges and indicator lights between a 924 and 911? I've found a source for a 924 voltmeter and the OXS indicator light I'm missing.
Would I be able to use a 924 OXS indicator in place of the 911 specific part?
For the voltmeter, I'm considering fabricating a mount in place of the ash tray and don't see any reason I couldn't use a 924 voltmeter. Am I missing something?
Any input would be apprecaited!
Old 01-17-2021, 08:19 AM
cycling has-been
bkreigsr's Avatar
The voltmeter should work in any car.
Two connections - hot wire and ground.
Mounting in the ashtray indent is a good idea - I have done several gauge placements there.
Oxygen sensor is a different animal and is made to communicate to the specific DME.
I think.
Bill K
Old 01-17-2021, 10:11 AM
Full Send Society
I put a voltmeter and USB port in my ashtray. Looks stock when closed.
Ashtray Modification (USB + volt meter install)
Old 01-17-2021, 10:42 AM
