Tachometer stopped working
My tachometer stopped working ,not sure if it's the tachometer or wiring. Any idea how to check?
You really need a tach tester or possibly a signal generator to test your tach. What year is the car?
75
Anyone nearby you can borrow another tach from? Some multimeters have a frequency (Hz) setting that you could use to test the tach signal to confirm it's getting to the tach.
I'd be happy to test it for you but unless you are in Socal it would require sending it back and forth |
| All times are GMT -8. The time now is 07:23 AM. |
