1979 911 SC
Feeler gauge
I've been searching Amazon for a set of feeler gauges that goes up to 1.2mm so I can use it to adjust the clutch cable but cant find anything that goes up larger than .88mm. Where can I find larger sizes gauges?
Semi thick business card.
I have stacked them up in a set.
add the numbers
82 SC , 72 914 |
Buy some of these ,
![]() then remove the hinge section and add feeler gauges to the correct thickness to Make these . ![]() ![]() And any left overs make these . ![]() ![]() ![]() Life is much easier in metric .... you can use your iPhone calculator
1979 911 SC
Thanks all, The thought had occurred to me to just do the math and use two together but I figured they were available somewhere. Didn't realize that most of us are just using two at a time and taping them together. Who knew? Thanks!
They can be bought if you REALLY need them , but for one-off jobs it’s not worth it for most .
If you have a spark plug gaper set it could go to 1.2 . If you must have a 1.2mm , you could try these relatively inexpensive plastic gauges . https://www.amazon.com/Rannb-Plastic-Feeler-0-05mm-Measuring/dp/B07TJCN4M3?th=1 |
Yep, stack some together to get what you need.
McMaster has plenty of options if you can't find what you need elsewhere. https://www.mcmaster.com/feeler-gauges It took me a lot of fiddling the first time I adjusted the clutch. Second time took probably 10 minutes. |
you can use a 0.050 inch feeler gauge or a piece of 18 gauge steel sheet. You would have a 0.003" error which for the clutch cable is negligible
