Do I need the AC condenser crash bar??
I'm deleting AC from my 80 SC... took out the AC condenser underneath the front bumper. Do I need to/should I keep the crash bar?
Part is circled in yellow in attached picture!
Old 01-19-2021, 10:50 AM
proporsche's Avatar
yah keep it .it does not weigh too much ..
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 01-19-2021, 10:58 AM
MBAtarga's Avatar
Removing A/C - I'd say take it off. It's worth at least 5 more MPH!
Mark
'83 SC Targa - since 5/5/2001
Old 01-19-2021, 11:09 AM
GothingNC's Avatar
I would keep it on,
Mine has helped prevent damage a few times.
John D.
82 911 SC Targa-Rosewood
2012 Golf TDI
Old 01-19-2021, 12:18 PM
I'd keep it
I hit the tabs even when careful on occasions
Hate to look under car and see the scrapes w.o it on ac deleted or not
PCA, POC & SCCA long time Member
Old 01-19-2021, 12:38 PM
I would remove it ! Then you will go at least 0-60 in 6.6 seconds!!!
Old 01-19-2021, 05:16 PM
kinda slow
shamrok's Avatar
No AC here, but use mine as a curb feeler more often than I'd like to admit.
Old 01-20-2021, 12:47 AM
Flojo's Avatar
WORD!!
it saved crushing my front valance so often.
especially when you have a lowered car (even at EU ride height).
a Turbo-lip will hide it.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 01-20-2021, 12:53 AM
Yea, it does not weigh much, and it will save potential expensive damage. Look at the bar on there now. See all the scrape marks and damage? That is what it protected the car from so far.
Old 01-20-2021, 06:52 AM
Keep it. You want to leave weight in the front of the car and remove it from the rear. Generally.
1973 911T Sepia Brown MFI
1986 Carrera Meteor Gray Metallic
Old 01-20-2021, 08:41 AM
Ok will keep it on. Have the valance off for spoiler install... assuming it covers the bar up/there is no interference I'll let it ride.
Old 01-20-2021, 11:16 AM
I deleted my ac and I removed the bar. If you remove the condenser and the screen, the bar protects nothing. Make sure you make a block off plate for the condenser blower hole. My bar was untouched, you are not supposed to use the car as a curb feeler. My car is slightly lower than Euro height and the first thing that hits is the front rubber spoiler. I also used it as an opportunity to clean up those front suspension bushing covers as well. BTW, my bar weighed 1.92 lbs. and total weight savings for the ac delete was 54 lbs.
1988 Carrera coupe
1966 250 Ducati
2015 VW Golf TDI gone because Dieselgate!
2021 VW Golf TSI
2014 Ninja 300
Old 01-20-2021, 06:52 PM
RDM RDM is offline
Coram Deo
RDM's Avatar
Originally Posted by 996AE View Post
I'd keep it
The tabs aren't part of the bar, so that wouldn't change.
The bar is below and slightly behind the valence, so I don't see how it protects the valence. Things you hit with the bar... you won't hit if you don't have the bar. that's my thinking.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 01-22-2021, 06:41 AM
DOH
Been too long since I was under my car
Great point
Thx
Old 01-22-2021, 07:47 AM
Flojo's Avatar
Originally Posted by Snitzler
if you can't weld, more elegant than screws would be JB weld and some seam sealer.
Old 01-22-2021, 07:55 AM
Flojo's Avatar
the bar sits lower than the tin valance bottom edge.
if you have a turbo lip it will be hidden nicely.
sure, when you ram smt that is higher (e.g. a curb) then the valance will be damaged.
but driving up/down a ramp that is too steep or similar, it will save you, trust me
Old 01-22-2021, 07:59 AM
esample's Avatar
You don’t need it until you scrape somewhere.
-e
Black Widow
Blk on Blk '86 911
"...the secret to Porsche: we do things others cannot"
Old 01-24-2021, 01:53 PM
