Engine number identification in 914-6 GT Tribute
I have a 914-6 GT tribute built originally for time trial and autox in CA. The engine was reportedly built by Gary Dielacher's shop. The engine serial number on the fan housing was either ground off or I thought this was maybe a blank case. There is no type number in that area either.
The car had set for many years with reportedly less than 10 hours on the motor. I redid the fuel system, rebuilt the webers, fired it up and it ran great. It's now out of the car to do valve adjust and some other maintenance/inspection. I did find an engine number near the pressure sender toward the rear. Is this normal? The engine casting number is 901.101.102.2R. It has 6 bolt holes on both the upper and lower valve covers. From other threads I'm assuming this originally was a 1970 S engine? Is that correct? http://forums.pelicanparts.com/uploa...1611328274.jpg http://forums.pelicanparts.com/uploa...1611328274.jpg |
That is an original 914-6 magnesium engine case. The serial number is stamped next to the oil breather on a 914-6 - Not by the fan support web.
They switched engine number locations on 914 installs due to the mid engine configuration.
BTW there is a big difference between 6 installs in the 1970 model year and race model. The 914/2.0 only had 100hp versus the 130 the 911 had that year. The race versions were 2.4-2.7 if I recall. |
The VIN# is also different. 914/4 start with 47 then a single digit for the model year. 914 for the original/6. The ignition switch was also on the left.
Not to mention counterweighted crankshaft.
http://forums.pelicanparts.com/uploa...1611333935.jpg http://forums.pelicanparts.com/uploa...1611333935.jpg |
My 70 conversion. Used a 3.0. Side shifter trans with LSD. http://forums.pelicanparts.com/uploa...1611335187.png
This car is a 901 side shifter so I'm assuming it is the transmission from the donor chassis. Chris Foley is building me his shift linkage kit and I'll be installing a rennshifter. I've driven the car a bit after I got it running and it shifted fine but we'll be looking at the clutch, etc. while the engine and trans are out of the car. The firewall shift rod bushing is shot so that will be replaced with the Tangerine unit. Knowing it's a 914-6 engine is helpful when ordering parts and for the spec sheet for my race club. I had been searching for 911 engine number information and didn't realize the /6 motors had the stamping where this one is. So helpful! |
So the engine is a Euro version type 901/36 from a 70 914/6. Look for the trans serial # on the rib along the bottom of the trans case. Get a photo of it if you can. Just beware of slipping oil from the breather on the top of the case. Most likely it will not have the original gear set, but you would have to tear it apart to find out. That would at least tell you what it was set up for.
The 914:6 had a taller final drive but was still a tail shifter. The number can be dragged off by speed bumps.
Quick update. I ended up connecting with the long time owner of the car yesterday and he was very gracious with taking time to fill in some blanks. He bought the 914-6 case and Dielacher's shop built it up. This was his description;
The case is from a European 914-6. ('70?) I never saw that car. I just bought the case used. The motor mount, steering column and other 914-6 original parts came from my ex-bosses car Ken Mack who used to own Sportech in Campbell CA. The dashboard (metal) was bought new from Porsche. The webers came from Gary's shop. 2.4 S with 2.2 S pistons and S cams. The 2.4 litre and the 2.2 litre are the same bore so mixing the higher compression 2.2 pistons with the 2.4 crankshaft (larger stroke) was a nice combination. Maybe 10.5:1 ? He confirmed the trans is either the 901 from this chassis or from a 74, stock gearing. Clutch is stock early 911 and new at the time this motor was put in the car. He had so many combinations of motors in this car over the years my notes were a bit confused and missing some information. He confirmed the motor has very few hours on it. Break in and maybe 2 time trial and autox events. |
The transmission # will tell you what base they used. The 914/4 transmission used the widest range of gears from A to ZD. None of the 911 or 914/6 used higher than ZA gear for fifth.
| All times are GMT -8. The time now is 08:01 PM. |
