Mark Wilson
Guest
Posts: n/a
Oil Temperature Sender loction?
My temp guage has gone wonky in my 79. I suspect the lead is loose from the sending unit. Can sombody point me toward it?
Thanks muchas,
Mark
Old 04-28-2003, 08:31 AM
Rick Lee's Avatar
Should be just below the oil pressure sender on the right side (as you're standing behind the car) of the pulley. You'll need a flat tip to get the lead off and a 19mm offset box wrench to remove the sender. A little oil will leak out too.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 04-28-2003, 08:46 AM
Mark Wilson
Guest
Posts: n/a
Thanks Richard. It was hiding in plain sight there. Got it hooked up and all is groovy.
Thanks again,
Mark
Old 04-28-2003, 12:39 PM
