Finding correct gauge sender...
Hello, I am making a custom gauge with some 911 VDO gauge parts and am trying to find the part number for the matching senders to the gauges I have. The two gauges in question are an oil pressure gauge from 0-5 Bar, and an oil temperature gauge with no scale. I believe these came from a '70-80s 911. I do not have the original gauge body so do not have the standard part number. I can give you the numbers stamped into the actual gauge electronics body.
Oil Pressure - 013056 9.80 Oil temp - 195198 9.80 Thank you for any help you may provide... Ben |
| All times are GMT -8. The time now is 01:56 AM. |
