-   -   Bilstein rollpin install help (http://forums.pelicanparts.com/porsche-911-technical-forum/1084119-bilstein-rollpin-install-help.html)
markmalin 01-23-2021 10:20 AM
I'm installing the roll pin on new Bilstein inserts.
- how do i know the shock insert is fully seated? (or is that a pointless question?)
- More importantly, how do you drive it back in? Just line it up and tap with a hammer, or is there a better way?
Mark
john walker's workshop 01-23-2021 12:40 PM
Stick a punch in the hole to line up the notch in the shaft with the hole. Leave the punch in while you drive the pin in from the other side. If you can pull the shock out while the punch is in, it's not down far enough. The split in the pin faces away from the shock shaft.
markmalin 01-23-2021 02:08 PM
Thanks!
Harpo 01-23-2021 03:41 PM
Good to know
