Angry I´m gating cazi
I am getin crazi
my 3.2l DME 911 some times wont start and when it does,
it go off at idle . I chek and there is not signal at the coil, inyecctor, fuel pump and spark plugs.
DME relay it is new, the DME has been cheked and is ok. the fly weel sensors are new, the ignition suitch is new.
the only way the engine starts is when terminal 20 is touched to ground.
if any one would give me some way to track the problem I will be very
thankfull.
sorry my english
Diego Nasti
Old 04-27-2003, 04:45 PM
Eric Mckenna's Avatar
Diego,
Private message Old_Skul he may be able to help you out with all that ,, as he has the same issues not long ago..
Eric
Famous last words..
"Hold my beer and watch this...'
" The reason the Irish are always fightin one another is that there are no other worthy opponents ".
Old 04-27-2003, 05:29 PM
Paco Anton's Avatar
Send a message via Yahoo to Paco Anton
Diego,
Bienvenido al foro!!!
I do not have a clue about your problem (little mechanical exertise plus I have a SC) but it is nice to have another Spanish speaking guy here!!!
Saludos
Paco Anton
83 SC Targa (Euro)
Old 04-28-2003, 07:27 AM
Team California
speeder's Avatar
Mucho Gusto!
Diego, Welcome! Sorry that I don't know DME either, but you will get the help that you need here. Also, there are some very knowledgable Spanish speakers/writers here.
Denis
Old 04-28-2003, 07:34 AM
THANKS FOR YOU REPLAY . it is glad to know that tere is people that read my post.
saludos
Old 04-28-2003, 10:22 AM
Diego:
It's been some time since I played with a DME system but, are you sure the DME relay is good? No power to coil, injectors or pump with the switch on usually means a bad main relay. Touching terminal 20 to ground (I assume you mean the DME terminal), to get the engine to start, seems odd also, I thought terminal 20 was for the main relay.
Hopefully someone with more DME knowledge will come up with an answer.
Jerry M
'78 SC
Old 04-28-2003, 02:00 PM
Bill Douglas's Avatar
Hi Diego.
Is you new ignition switch wired in correctly?
Hasta leuago, Bill.
Old 04-28-2003, 04:20 PM
Bill, yes the ignition switch is wired correctly, i cheked it a cuple of times.
Thanks.
Old 04-29-2003, 04:35 AM
Jerry, The main relay is new and i have two of them,
the gound is fron wirred harnes and you can hear the fuel pump
working, I´m buying the therd main relay and see.
thanks.
D.NAsti
Old 04-29-2003, 04:44 AM
