What's Facebook?
SS Braided chain tensioner oil lines
I have been considering replacing the hard lines for the chain tensioner on my 3.0l to braided hose. These hard lines are soldered to the ball and I’ve experienced untimely breaks while on track. I’m thinking 2-an hose and sourcing the metric adaptors for the oil line up top and the banjo below. Before I recreate a wheel, has anyone sourced the fittings or found hoses already put together.
Cheers
Turborat "’Cause every once in while, the lion has to show the jackals who he is” 1979 911 SC - 2100 LB track rat 1986.5 928 5-Speed - 36,000 miles 2001 330Ci |
![]() There are normally some "anti-vibration" supports to keep this from happening. Do you have them or are they failing even with the supports? Len
What's Facebook?
Paul |
Greetings Len!
I sent you a quick email as your inbox is full. Thanks, DJ |
