-   -   Unique CIS/ K-jetronic problem, I think... (http://forums.pelicanparts.com/porsche-911-technical-forum/1084541-unique-cis-k-jetronic-problem-i-think.html)
AlexJ 02-18-2021 03:06 PM
Originally Posted by boyt911sc (Post 11228756)
Alex,
When you did the fuel pressures testing, were you running the motor or just the fuel pump? I am not sure about your test procedures and if you could confirm which method you used, I might be able to explain some of the discrepancies you have observed. Keep us posted. Thanks.
Tony
Just to recall, wur from a 911 SC euro version
I repeated the readings today, after trying to set both pressures (cold and warm).
Cold control pressure: fuel pump relay jumped, wur plug disconnected, key on, valve on gauge open, 1,1 bar - car not running.
Connected the wur plug, fitted fuel pump relay, Drove it up to the running temperature and when stoped, gauge was showing 3.6 bar with both upper and lower vacuum hoses connected.
When I disconnect the lower vacuum hose on the warm control pressure drops to 3 bar.
AlexJ 02-18-2021 03:10 PM
Waited for another 25 min and...
Car struggles to fire when hot and now also when cold...
... and always with same symptoms... after starting it is not lean, it sounds there is not enough fuel but after pressing the gas pedal, it stabilizes...
SkiVT 02-18-2021 03:43 PM
WCP is primarily created by plugging the power source to the wur. The engine does not have to be running, or even present, as Tony’s setup shows. You can test for CCP with that plug disconnected. You then plug it in to get to WCP. Do this with the fuel pump jumpered so no engine start is needed.
SkiVT 02-18-2021 03:51 PM
Can you post a picture on the vacuum line from the wur (lower line on side of wur) to the ttv showing the connection points on the ttv?
boyt911sc 02-18-2021 05:02 PM
WUR test and calibration.........
Alex,
Since you are using the FP and relay socket to test your cold control fuel pressure, you could do the same with the WCP (warm control pressure) and avoid driving the car. You are wasting your valuable time and fuel unnecessarily.
Your understanding of CIS is somewhat flawed but could easily be corrected by practicing the correct test procedures. SKIVT (Stuart) has given you a hint and he’s a sharp troubleshooter including Walt F. and other guys in this forum. The reason it is taking this long to solve your CIS problem/s is the way you communicated and your feedback. Instead of giving numbers for your fuel pressures, you tend to use words like they are in spec, they are new, they are good and OK.
Forget the past. This is what I would do if I were in your shoes:
  • Measure your control fuel pressures (CCP & WCP) just using the FP. No need to drive the car.
  • Measure the WCP again and apply 16” Hg vacuum. You would need a hand held vacuum pump.
  • Measure the system pressure (valve close).
  • Test your residual fuel pressure after 20 mins.
  • Test your fuel injector’s spray patterns. They should have mist-like v-pattern shape. Not jet like spray patterns.
  • Check for unmetered air. This is probably the reason you are having difficulties re-starting a warm motor.
  • Post a picture of your throttle body and decel valve.
  • What is the Bosch ID # for your fuel distributor? Last 3 digits?
Your WCP with and without vacuum are good. So what is preventing it from re-starting?
  • Residual fuel pressure
  • Test your fuel injectors for drips and spray pattern.
  • I bet you have unmetered air.
You need to test and confirm the absence of unmetered air going into the system. Keep us posted.
Tony
AlexJ 02-18-2021 11:12 PM
First of all, I would like to thank you all for your insights.
I will try to be more specific next time and also improve my english...
I will check everything following Tony’s suggestion and post the results.
AlexJ 02-18-2021 11:13 PM
Sure! I will post more photos next time I do readings... soon...
AlexJ 02-18-2021 11:46 PM
Just for clarification: If I run the test the way you suggested, after some time I will get the same WCP as if I take the car for a ride for some time?
AlexJ 02-19-2021 02:47 AM
Here is a photo showing the mentioned hose (1):
http://forums.pelicanparts.com/uploa...1613731631.jpg
AlexJ 02-19-2021 03:02 AM
I think I found already a mistake...
http://forums.pelicanparts.com/uploa...1613732473.jpg
SkiVT 02-19-2021 03:08 AM
It looks like you are missing number 4 in this diagram, the TTV. It holds off vacuum for a short time when the engine is started. It heats up from power and opens to vacuum in about 45 seconds. I am not certain at what temperature it closes when the engine is shut off. In any case, your measurements while the engine is running are always with vacuum unless you plug the vacuum line. At cold or cool start, your pressure could thus be higher/leaner than optimal. After following Tony’s instructions, you could test this as a problem by duplicating your “hot starts” with the vacuum line at the WUR plugged with a golf tee or similar. I dont think the TTV is a problem for a restart 5 min after turning off a hot engine. It may or does become a problem the longer the engine cools before a restart.
http://forums.pelicanparts.com/uploa...1613732374.jpg
SkiVT 02-19-2021 03:09 AM
Our posts crossed!!!!
AlexJ 02-19-2021 03:14 AM
Found another strange thing (it was not me who assembled the engine)...
Found this valve behind the air pump...
Wasn’t it supposed to be on the other side, next to the auxiliary air valve?
http://forums.pelicanparts.com/uploa...1613733088.jpg
One of the vacuum hoses comes from the throttle body and the second one goes to the air pump next to it.
SkiVT 02-19-2021 03:21 AM
The hose connected to the top of the wur by the electrical connection is not vacuum. It just vents to atmosphere.
Make sure the vacuum line from the wur to the TTV you just found connects to the outer connection on the TTV exactly as shown in the diagram.
On my 83 euro, the TTV is mounted to the bracket to the left of the decel valve that you circled in your picture using the welded nut on the L bracket. So it sits higher not touching the engine which may or may not matter.
I dont have an air pump so have no idea how that may or may not be interacting.
SkiVT 02-19-2021 03:30 AM
http://forums.pelicanparts.com/uploa...1613734192.jpg
SkiVT 02-19-2021 04:28 AM
In your spare time watch the pressure change on a cold start about 35 seconds in when the TTV opens. Again, this may or may not matter and is secondary to first being sure the ccp/wcp are correct, no unmetered air, etc.
https://youtu.be/x3HXhqlwFMM
boyt911sc 02-19-2021 06:00 AM
Better communication...........
Alex,
You and Stuart have the same engine and should be able to sort all your CIS problems. See how good communication makes the troubleshooting much easier and faster. Anyway, you are in good hands. Both Stuart and Walt, etc. have incredible ways to look at things. And they have the patience to compose detailed explanations that reminds me of Ossiblue (Larry). They are good teachers and their knowledge is very reliable.
Tony
AlexJ 02-19-2021 07:41 AM
Stuart and Tony, thanks for your good will! Has been very helpful and helping me modifying my approach.
One question: when I have my vacuum connections corrected, will the pressures be affected?
SkiVT 02-19-2021 08:14 AM
Vacuum happens when your lines are connected AND your engine is running. Your wur changes pressure in the presence or absence of vacuum, in addition to as it warms up. So as your engine idles, you have vacuum and it increases your pressure versus having no vacuum. When you drive at full acceleration, vacuum drops and your pressure drops, enriching your fuel mixture and putting a smile on your face. For testing, you can introduce vacuum using a hand held vacuum pump, as Tony mentioned, without ever starting your engine. You can match your pressure readings with and without vacuum to the specs for both CCP and WCP.
http://forums.pelicanparts.com/uploa...1613751108.jpg
AlexJ 02-19-2021 12:11 PM
So, I have been testing CCP with the vacuum line connected... but with the engine off...
meaning I have to do it again with the vacuum pump applied (if I remember, Tony mentioned the value). That is why I found the value under specs...
AlexJ 02-19-2021 12:14 PM
Bad news...
Somehow the wur stoped working...
When checking the voltage arriving to the wur plug, (read 10,5 Volts, car not running), and after plugging it again I noticed the pressure was not rising...
Tested the connectivity and... infinite!
Here is the faulty part:
http://forums.pelicanparts.com/uploa...1613765640.jpg
AlexJ 02-19-2021 12:18 PM
Tony was right! I should have never touched this wur...
No I realize that I have been searching at the wrong place...
This is really frustrating... what else?!
AlexJ 02-19-2021 12:32 PM
Originally Posted by boyt911sc (Post 11230629)
Alex,
[*]What is the Bosch ID # for your fuel distributor? Last 3 digits?[/LIST]
Tony
Mine is:
http://forums.pelicanparts.com/uploa...1613766703.jpg
SkiVT 02-19-2021 01:20 PM
The 097 is the correct FD. The pressure value difference with and without vacuum is around the .6 you saw when you pulled off the line with the engine running. When you are setting the CCP and WCP you do need to be sure which values you are using. The CCP chart is with vacuum. Getting yourself a mitivac would be helpful. Obviously you need to resolve the power/part issue.
Walt Fricke 02-19-2021 02:37 PM
Since I don't have a vacuum WUR on my US '82, I don't have much practical knowledge of its effects, nor a sort of memorized schematic for it (all that extra plumbing). However, for grins I once applied a vacuum to the upper (atmospheric equalizing) port of a WUR. It raised the CP. I applied a vacuum to the lower (unused, in my case) port. It lowered the CP. At least, that is what I remember (which could be backward?).
Why? I supposed it had to do with the barometric diaphragm in the WUR which supports the base of the inner of the two springs (the outer spring base is the WUR case, so doesn't vary).
http://forums.pelicanparts.com/uploa...1613773182.jpg
Vacuum in upper chamber, more pressure upward from the center spring. Vacuum in lower port, less pressure upward from center spring.
This would suggest that, absent other controls in the system, that wide open throttle with a lower port vacuum attachment would have a higher CP (leaner), and idle a lower CP (richer).
With no vacuum application, this barometric diaphragm would provide a measure of altitude compensation.
But theory aside, now that you have people with knowledge of these vacuum systems involved, and you can figure out what is incorrectly connected or not functioning, which is where suspicion is moving here.
And if the heater coil on the bimetalic spring element has quit working (easy to check with an ohmmeter), I believe you can get a replacement, either of it or of the spring with heater.
By the way - your English is perfectly functional, and as grammatically correct as is usual on this forum. Tony is just coaching you on troubleshooting techniques. Besides, about all I know about Portuguese is that the C is soft (at least it is in my friend Goncalves' name).
boyt911sc 02-19-2021 05:41 PM
Clarification......
Originally Posted by Walt Fricke (Post 11231864)
.........(edited).........
.............(edited).........
Walt,
The picture of the WUR posted above is NOT the same type of WUR used in SC’s (‘78~’83) whether US, ROW spec. lambda or without lambda. The WUR that Alex has is -089 (vacuum assisted) and totally different in operation and configuration. Two (2) totally different WUR’s. This particular type of WUR was last used in 911 CIS for 1977 models.
Alex,
Your broken WUR-089 just needs a replacement heater. There are two (2) heater resistances used in WUR-089, they are the 30 Ohms (Germany) or 35 Ohms ( France). Your WUR probably has the “Germany” cast on it. The replacement heater/s is available and I just received some from an European seller. Walt’s post is very informative but be aware that your WUR is not the same in operation and configuration.
Tony
Walt Fricke 02-20-2021 03:28 PM
Tony - do you by chance have a similar Bosch based diagram of the 089 in your collection?
My impression is that, schematically, there is very little difference between the WURs Porsche used, and, for that matter, other car manufacturers used. The values differed, of course, as did using or not using vacuum. But understanding how the components worked, with due consideration for differences like what vacuum, if any, was employed, allows some cross model understanding when attempting a differential diagnosis.
That is a bit different than knowing very practical things like (wow) the difference between Germany and France resistance heaters.
I have long been interested in just what the differences actually are in the various WURs in terms of the individual parts which affect the values. Some may be just in how they are hooked up. For instance, the one shown puts a vacuum on the upper chamber, but later ones just used that connection as a source of (filtered) atmospheric pressure.
Are the two internal coil springs different between models? The module which holds the springs is screwed into place. Is it different, or is its height setting - how far it is screwed in - different?
Is the barometric diaphragm set up differently between models or is it the same part, with the same air pressure trapped inside its two halves? Or am I wrong in thinking it is like what you find in a barometer, and it is really just a diaphragm separating the upper from lower chambers (which is what the schematic shown looks like), and just adjusts the resultant force of the lower chamber spring and the upper chamber spring? Or did vacuum assist models use just a diaphragm, and non-vacuum models used a concentric ribbed barometric diaphragm?
It is easy to see how Bosch had a way of setting the depth of the two upper steel cylinders when manufacturing a WUR to the specs they and the car company worked out for cold and warm pressures - the same parts could just be set at different depths in the aluminum housing.
I admit to a special interest in this because the '82 US 3.0 I purchased from someone far away did not have the 089 WUR - it had the 033, and I had no reason to think the owner had tinkered with things. Tony pointed out to me that this was the wrong WUR, but its control pressures were correct for an '82 and the engine ran just fine once I hooked up the oxygen sensor system. It had the tube for lower chamber vacuum, but there were no vacuum lines attached.
It wasn't until I got a recording AF meter that I started messing with it. It subsequently was replaced by a shop with the 089 (shop had same reaction - wrong WUR), but in terms of race track AFRs, they still are puzzling. However, I don't recall (car is in storage at the moment) that the 089 uses any vacuum assist - the fuel distributor doesn't have an unused port, and there are none of the extra devices shown in the earlier schematic, and the O2 sensor system .
But it looks like Alex has finally advanced things to where he can check vacuum connections, and perhaps also try to locate possible unmetered air leaks. It makes sense that those would have the most effect on the air fuel mixture at the quite slow RPMs (~300 RPM) created by the starter. Unmetered air leans the mixture. When he blips the throttle after the engine finally starts, it seems to work fine as I recall. Hot start CPs are higher to begin with, and the cold start valve is apt not to be operative.
A search of this forum will provide a lot of information on how one can test for such leaks. Quite recently Tony showed how he made a smoke machine to use for this purpose. Less precise methods involve spraying a flammable substance around the various rubber fittings to see if idle speed increases. Carb and brake cleaner will work for this, as will propane from an unlit torch.
SkiVT 02-21-2021 05:22 AM
Walt
The last two entries in the linked thread I think explains how it works. Finding a diagram of the internals for WURs is a challenge.
http://forums.pelicanparts.com/porsche-911-technical-forum/117725-lets-connect-wur-right.html
'78 SC 02-21-2021 08:00 AM
Here's a photo of a 045 WUR showing the underside of the pressure cell and the vacuum connection.
http://forums.pelicanparts.com/uploa...1613922968.JPG
The following two photos show the result of applying vacuum to the port. Note there are two springs. The outer sits on a fixed support, the inner sits on the moveable seat connected to the diaphragm.
Under vacuum (as would be the case for idle and cruise), the inner spring seat rises up, increasing the control pressure and leaning the mixture.
At atmospheric pressure (wide open throttle), the seat sinks down, lowering control pressure and richening the mixture. Total movement is about 0.5 mm.
AlexJ 02-22-2021 06:20 AM
If anyone knows where I can find (Europe) the heating element (30 ohm) resistance, please lemme know.
It would be of a great help!
Ginger77 02-22-2021 06:50 AM
Check out this store named Missing Parts. https://www.ebay.nl/str/missingpartsde
Highly recommended. If you can't find what you need, send him a PM.
boyt911sc 02-22-2021 01:53 PM
Contact information.........
Contact Info@missingparts.de and address it to Ruben. He has been very helpful in answering technical inquiries.
Tony
boyt911sc 02-22-2021 03:43 PM
The difference between WUR’s........
Walt,
I will try my best to explain the difference between these WUR’s:
  1. Vacuum assisted WUR from top........like WUR-033
  2. Vacuum assisted WUR from bottom port.......like WUR-045/-069/—089.
  3. Non-vacuum assisted WUR.....like WUR-072/-090.
First let’s us take a closer look at these WUR’s: So I picked several WUR’s and use them as demo for our discussion. They are WUR-033, WUR-045 (same as WUR-089 except for the heater value), and the lambda WUR-072 & -090. The first picture shows the completely assembled WUR’s and you will notice the difference between them just by looking closely.
http://forums.pelicanparts.com/uploa...1614031270.jpg
The next picture is the partially disassembled sections of the WUR’s. Oooops! I forgot the springs for WUR-045.
http://forums.pelicanparts.com/uploa...1614033123.jpg
Ok, I located the springs and installed them. The inner or outer springs for the vacuum assisted WUR’s are identical. So mixing the parts is not critical. And you could see the components for these WUR’s are some what similar but not the sections.
http://forums.pelicanparts.com/uploa...1614033346.jpg
Let’s go now to the schematics: Below is the WUR diagram for WUR -033. When you apply vacuum at the top port (#3), the “spring cap” where the inner spring sits would go up and increase the fuel pressure reading. However, if you apply vacuum to the vent port, the inner spring will not rise up. For this particular WUR-033, the vacuum chambers consist of the upper and middle sections.
http://forums.pelicanparts.com/uploa...1614034318.jpg
Below is a modified diagram for WUR-045/-089. I can not find from my books a good diagram so borrowed the WUR-033 and made some drawings. In comparison to WUR-033 (above), WUR-045/-089 have a totally different vacuum chamber configuration. The vacuum chamber is located solely in the middle section. And you could test it separately as a stand alone component. Plus this type of WUR has double diaphragm and allows the middle section to be an independent vacuum chamber from the top and bottom sections. Another added feature is that it is adjustable. WUR-033 and similar WUR are non-adjustable.
If you apply vacuum at the top port, it won’t increase the fuel pressure. Only at the side port where vacuum causes the fuel pressure to increase.
http://forums.pelicanparts.com/uploa...1614034555.jpg
If your car is a late SC US spec. it should not have a WUR-089 which is vacuum assisted. And your fuel distributor should be FD-077. I don’t remember if it was FD-031 or FD-077 you received from me but check it for me. It has been so many years since you got the FD from me. Do you have a specific question or test we need to do?
WUR-033 or WUR-045/-069-089 will work with FD-031 but not with FD-077 with lambda/OXS.
Tony
AlexJ 02-23-2021 01:36 AM
Many thanks!
AlexJ 02-23-2021 01:37 AM
Tony
Obrigado!
AlexJ 03-03-2021 04:21 PM
Back to this thread...
A new resistance installed.
http://forums.pelicanparts.com/uploa...1614817242.jpg
preparing for new measurements...
AlexJ 03-03-2021 04:26 PM
Starting with the cold control pressure:
Applied 16 hg vacuum on the wur, plunge the fuel pump relay, plug disconnected:
http://forums.pelicanparts.com/uploa...1614817511.jpg
1,5 bar CCP
AlexJ 03-03-2021 04:32 PM
After this, connected the wUR plug, vacuum still attached,
http://forums.pelicanparts.com/uploa...1614817702.jpg
AlexJ 03-03-2021 04:42 PM
The photos are not in order...
The correct order:
Right after connecting the wur plug, (15:36), WCP 1,6 bar
(15:38), 2,6 Bar
(15:40, 3,5 bar
(15:42), 3,7 bar
Right after, started the car, went for a ride till the engine reaches running temperature.
When arrived, WCP looking a bit higher.. 3,8 bar.
http://forums.pelicanparts.com/uploa...1614818381.jpg
AlexJ 03-03-2021 04:47 PM
... waited for another 20 min. , checked the residual pressure, (1,1 bar), started the car and... the same.
Struggles to start and when it starts it misfires (same as if the residual pressure is below specs, the car struggles a bit until system pressure is achieved).
Throttle down twice and the car is fine.
Note that after the last events and some wur tuning, the cold start became much more difficult.
