1966 rear sway bar
I am installing a rear swaybar and bracket assembly on a 1966 911. Any pictures or templets/measurements on where the 'weld to chassis' swaybar brackets attache and where the ball locates on the bannana arm. I have made the job more difficult as I had removed one of the arms as we are doing a powder coat on all of the suspension pieces then realizing I needed all of that in place to take my measurements. I doubt if there is a map for this but thought I would ask as locations of the weld on pieces is fairly critical. Thanks, Bob
The 9 Store
A pelican by the name of "Haul" has a copy of the factory manual. Contact him. It has the dimensions for the trailing arms and the body.
All used parts sold as is. |
