Clutch release bearing questions
What are the secrets of removing the roll pin and replacing it?
Old 02-04-2021, 08:52 AM
Drive it out with the fork angled out so the pin doesn't hit the case and jamb things up.
Stick a punch in the fork hole to line up the shaft notch, them pull down on the fork to keep it in position, pull the punch out and tap the pin in.
206 637 4071
Old 02-04-2021, 09:07 AM
Your talking about the release fork pin? I just did this job..
I tapped it from the inside, then realized I have to take the
Guide tube off and tap the pin again with Allen key ( use the
Short end to gain more room). Shaft came off..
I have a question though.. I forgot to mark the fork orientation
With the clutch arm under the trans.. can somebody verify?
Old 02-04-2021, 09:10 AM
proporsche's Avatar
don`t forget to put on the shaft the rubber seal ..i like to put on top and bottom for easier will be just the bottom under the fork and plenty of lubrication on the shaft...
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 02-04-2021, 09:22 AM
kevingross's Avatar
What John said. I put a small block of oak between one of the fork tines and the case to keep the fork angled such that the pin doesn't drive into the case, and that I have a good angle to tap. I have a set of ball-head punches from Snap-on that work well with these tension pins.
When re-installing, "back light" the fork and bellcrank with a flashlight, look through the hole in the fork to see, thanks to the light, that you're lined up correctly with the radius in the bellcrank.
I use a high pressure grease, light smear, where the bellcrank rides on its three bushings in the case. And I use a thick anti-seize on the splines. Cutting a seized fork off its bellcrank is a joyless process.
Kevin
Catellus Engineering
catelluseng@gmail.com
http://www.catellusengineering.com
https://www.facebook.com/catelluseng/
Old 02-04-2021, 01:29 PM
How did it go? U got the pin out?
Do you know the orientation of the fork to
The lever? Are they aligned flush?
Old 02-05-2021, 09:29 AM
Yes I got it out and replaced. There were a few choice words getting the pin back in but I persevered!! I am sure the German engineer who designed this is smiling or laughing his ass off!
Old 02-05-2021, 09:58 AM
