fresh air blower
I am rebuilding the fresh air blower unit on my 1987 Porsche 911 carrera. I would like to rebuilt the flaps inside the housing that open and close and control the air flow. The rubber seals are completely worn (see pics). Can they be purchased? Thanks
Old 12-31-2020, 12:25 PM
I could not find them in the PET when I refurbished my unit last year. I ended up making a pair out of an old mouse pad.
Jeff
'70 T/ST Tribute- 3.6/G50
'98 C2S, '95 Carrera, '90 Carrera 2, '87 Carrera - all sold
Old 12-31-2020, 01:12 PM
6 cylinder symphony
I did something similar a few years ago. I found some on E-bay that someone had made. The "mouse pad" foam is a good idea if you have something to cut the circle well.
'84 3.2 Targa
'89 964 Coupe
"What do you mean NEXT project?" - my wife
Old 12-31-2020, 01:44 PM
Thanks very much. I will give the mouse pad a try. Clever.
Old 01-02-2021, 07:14 AM
For those who are interested using black foam works perfectly to restore the flaps. I am attaching the picture.
Thanks again for the suggestion.
Old 01-09-2021, 12:41 PM
Neoprene wetsuit material is what i have used
Old 01-10-2021, 12:05 AM
superninety's Avatar
What thickness neoprene or foam and where did you locate it?
I tried a sheet of rubber that is 1/8" thick, but that is too thick with that material
Thanks !
Robert Callaway
PCA | Early S Registry | R Gruppe
1970 T Coupe, 1990 C2 Coupe, 2007 Cayman S
1962 S90 Coupe - Gone, but never forgotten...
1985 Targa - A distant memory...
Old 02-06-2021, 08:43 PM
creaturecat's Avatar
i repurposed a piece of the black foam - traditionally used to line the bottom of a tool box tray.
worked perfectly.
Old 02-07-2021, 06:41 AM
I bought some from 914 rubber.com they are the same . https://914rubber.com/flapper-valve-seals-in-blower-housing-1
Old 02-07-2021, 08:09 AM
I used 1/16" rubber sheeting found in the local hardware store plumbing department to cut the circles. I wish it were black, but ....
Seals very well and will last far longer than foam.
https://photos.app.goo.gl/rjmRhZEqePosQpky8
Robert Callaway
Old 02-08-2021, 07:43 AM
