Len 911's Avatar
Oil sender leak ?
Ok. I replaced the triangle of death items years ago..i noticed that oil is leaking from under the oil sender where the adapter screws into the case..can I just unscrew it from the block or is this a problem to do..is there a crush seal under it. Or should I just try and tighten it a little more 🤔..im afraid of stripping the case.
Thanks for your inputs
Old 12-28-2020, 06:09 PM
Send a message via AIM to fintstone
There is a seal. You should be able to gently tighten it a little. If you have to replace, it is pretty straight forward. This is what the part looks like (simple threaded) in the car=talog:
https://www.pelicanparts.com/More_Info/91160623000OEM.htm?pn=911-606-230-00-OEM&bt=Y&fs=0&SVSVSI=807
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 12-28-2020, 07:32 PM
Len 911's Avatar
What about the part that is in the engine case that the sensor screws into..does that just unscrew and is there a crush washer under it..?
Old 12-29-2020, 04:33 AM
Flojo's Avatar
unscrew. new crush washer required.
never re-tighten or re-use used crush washers!
it is alas a too common failure. even newly installed senders leak.
either leak by themselves (most compound glue the sender body prior to install) or the crush washer leaks.
I know a few guys that block that bore and install the sender elsewhere.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 12-29-2020, 04:51 AM
While your in there, it's been suggested that a bead of JB Weld
on the oil pressure switch as a preventative cure for a very common leak area.
Found this photo in search. Shows exactly where the JB Weld goes.
_______________________________________________
45 yr addiction 1965 356 Coupe, '70 914- POS, '74 911- lightweightFUN, '83 SC Cab- 100%AnalogOpenTop.
Old 12-29-2020, 11:08 AM
Len 911's Avatar
What size crush washer is under the adapter..i see where some say 18x22. I cannot find them local i see 18x24 will that work..i already placed a big order from our host..just need one quickly
Old 12-29-2020, 12:34 PM
New switch arrives this week, should I do this, or is this to repair an existing one?
Old 02-08-2021, 02:44 AM
GothingNC's Avatar
Seal up the new switch too with JB Weld to prevent future leaks.
John D.
82 911 SC Targa-Rosewood
2012 Golf TDI
Old 02-08-2021, 04:42 AM
