911SCRVA's Avatar
'81 SC oil consumption/oil loss problem
A while back, I noticed that my 911 was either losing or consuming too much oil.
The details:
I've had to add a couple quarts of oil after only a few hundred miles.
I don't know what kind of oil all the previous owners used, but I know the mechanic preferred Liqui Moly. When I noticed the oil level had changed pretty dramatically, I was forced to use Mobile 1 15W50 because I was on the road and that was my only choice.
I occasionally get a puff of white smoke when I'm on the highway, but rarely.
The exhaust has started to smell a little rich.
There are oil spots beneath the car, but nothing dramatic.
The oil gauge, which used to perpetually rest at empty (regardless of it not being empty, but not uncommon from what I hear), but it has begun acting erratically, flicking all the way to full and then bouncing back and forth.
I reached out to the mechanic who has serviced the car for all of its previous owners. This is what he said:
"As you know, the car has compromised oil plumbing on the passenger rocker area. This plumbing leads from the engine to the oil cooler in the passenger front fender area. It is and has been a small seep of oil loss. If this has turned into a “drip” (where it is leaving oil accumulation on the ground OR dripping oil while car is running) then this can also attribute to changing oil levels on your dipstick. A change of a seep to a drip can happen at anytime."
This was all news to me, but that's irrelevant at this point. My problem now.
How would you recommend I proceed trying to solve the loss/consumption issue?
I found an article "How to Replace the Hard Oil Cooler Lines on an Air Cooled Porsche 911". Is this my next step? Or are there a number of smaller, simpler things to try first?
I could bring the car to the mechanic to do forensics and repair, but I'd like to attempt to do this myself.
Thank you for your help.
Old 11-11-2021, 05:28 AM
proporsche's Avatar
hi, from all of this info i do not see how do you check your oil level? And how many Q per 1000 miles?
Ivan
1985 911 with original 501 645 miles...807 319 km
Old 11-11-2021, 05:41 AM
911SCRVA's Avatar
Ivan
Since buying the car, I've driven it 2,178 miles and have added four quarts.
Old 11-11-2021, 06:00 AM
Unless you see a LOT of oil pooling under the car (or, with the engine running and at full operating temperature, you observe oil dripping out of the oil lines under the passenger rocker panel leading from the engine to the oil cooler just in front of the passenger side front wheel) , don't think "losing oil" is your issue. A VERY small amount of oil (say a teaspoon) creates a surprising large oil spot. I echo Ivan's comment above -- how are you checking your oil level (you should only use the dipstick and only check while engine's fully warmed up, running and sitting on level ground).
You should also ignore the oil gauge's gyrations -- this is a sign that the sending unit's going bad (or there's a continuity issue in the wiring between the sending unit and the gauge), only trust the dipstick to show you the actual oil level.
Ultimately (and assuming you're using the above methodology to check oil level and add oil), unless you discover a gusher (or a significant amount of oil coating the underside of your car), sounds like your issue is oil consumption (the engine's burning the oil while running), with the common culprits being either through worn valve guides or piston rings.
How many miles are on the car/engine?
Old 11-11-2021, 06:02 AM
911SCRVA's Avatar
Ivan
Sorry, I missed the first question. I check it parked on a level surface while it's running, preferably when the engine is hot (but sometimes when it's only warm). But there are so many atmospheric variables (I've been told) in getting the engine hot, I don't even know I've ever truly gotten the engine hot, even on hot summer days driving it 100 miles.
Old 11-11-2021, 06:35 AM
911SCRVA's Avatar
Thanks, Darrin. The car/engine has 122,442 miles. (The mechanic says it's time for a rebuild, and although I'm definitely a novice, I've seen scant evidence the engine needs a rebuild.)
I do check the oil with the dipstick and only after the car has been running for at least 30 minutes, preferably highway driving. But I've been told it's nearly impossible to know what the true oil level is unless the engine is optimally hot. Would you say that the car, when idling at warm temp (not hot) that the oil level should sit between the low and high markings on the dipstick?
I'll check the car later today for dripping oil lines after I get it on the highway.
--Kurt
Old 11-11-2021, 06:50 AM
creaturecat's Avatar
that's an acceptable amount of oil usage.
add when necessary. monitor usage carefully.
or buck up. your choice.
have you viewed the oil line that is suspected to be contributing to the loss? fitting weeping? etc? there are aftermarket solutions available - to minimize the pain of installing a new oil line.
Old 11-11-2021, 06:57 AM
911SCRVA's Avatar
Thanks for your response. What would you say the acceptable range is? And when you say "or buck up, your choice", do you mean live with it as it is or spend the money to replace the lines?
I haven't inspected the lines. I'm new to this, so I'm not sure what I'd be looking for. Any tips?
Old 11-11-2021, 07:02 AM
proporsche's Avatar
That is basic oil usage...1-2 Q per 1000 miles is normal in your case plus some drips makes it ok...of course the less the better.If you have a white smoke in the morning-or cold that is your valve guides,if you see puff of white smoke while driving piston rings....
clean the engine and see where it drips-or take a picture before cleaning so i can see....
Ivan
Old 11-11-2021, 08:07 AM
Lash
I think if there was a hole or break in the oil cooling lines running to the front fender you would see a significant amount of oil splatter around the oil lines. Also if there is a hole forward of the external oil thermostat you maybe loosing oil when driving the car as the thermostat will open when oil temperature is hot. Either way you should see visible signs of the oil leak
Before you jump into an engine rebuild consider fixing the oil level gauge or sender first. Make sure you have the proper amount of oil. Drive the 911 and keep tabs on the mileage driven and oil usage.
When driving, the engine temperature gauge after ten miles or so should be reading normal, when your engine is idling and your on a level surface the oil level indicator should be near the 3 o-clock position
Lash
1963 356 T-6 Normal Coupe
1972 911 T Coupe ..... Sold
1972 911 S Targa ...... Sold
1980 911 SC Coupe Weissach
Old 11-11-2021, 08:38 AM
MichaelSJackson's Avatar
I agree with darrin. Treat the oil level gauge as nothing more than a fancy idiot light, at best. Still nice to have it working.
I quit trying to top off the oil, long ago. I check mine fanatically and try to keep the level dead in the middle. Minimizes leaking pass the valve guides while parked. Parking on the tilt also aggravates valve guide seepage.
I'm not saying you shouldn't chase this down. It's best to know what's going on.
Old 11-11-2021, 09:06 AM
911SCRVA's Avatar
Ivan
Thank you, Ivan. I have a stupid question (as a novice, I reserve the right to ask stupid questions): Do you mean just a regular old picture of the engine, or is there something in particular you'd like me to focus on?
Old 11-11-2021, 09:37 AM
Still here
pmax's Avatar
You can also pull the plugs using that nifty tool and see how they look.
Old 11-11-2021, 09:41 AM
911SCRVA's Avatar
Originally Posted by pmax View Post
You can also pull the plugs and see how they look.
Again, reserving the right to ask stupid questions: How do I diagnose what I see?
Old 11-11-2021, 09:44 AM
proporsche's Avatar
take a picture of your oil leak-drip and the bottom of the engine.....
For the plugs if you take it out take a picture again and show to PMAX and us
Ivan
Old 11-11-2021, 09:52 AM
New-ish 911SC Targa Owner
pampadori's Avatar
911SCRVA - are you in Richmond? i'd be glad to take a look at your car and see what can be seen and help with diagnosis.
Feel free to text me if you want a local set of eyes to take a look.
540-537-1545
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 11-11-2021, 10:35 AM
911SCRVA's Avatar
Ivan
I just took the car for a 30 min spin and looked under it to see if there was a drip. I knelt there for a while and saw nothing.
I'll take a pic of engine's underside as well as the plugs. But I'm going to have to do it tomorrow a.m.
Thank you all for your help on this!
Old 11-11-2021, 11:08 AM
911SCRVA's Avatar
540-537-1545
I am in Richmond. I'll text you. Be good to meet a local owner anyway.
Old 11-11-2021, 11:09 AM
Reiver
Reiver's Avatar
IMO that is a lot of oil for that many miles.... I have about 121k on the bottom end and 55k on the top and burn about 8-10 ounces every 3k miles. I do drive it hard. '83 930-10.
I had an '83 930-16 (as you have) with 230k miles and it burned about what you have now at half the miles.
Have you checked all of your head studs.... the play in your valves. I'd suspect some serious valve guide wear here.
Now, if you were tracking it and always driving at wot perhaps but normal driving at that mileage indicates serious wear of the top end.
De Oppresso Liber
Strength and Honor 5th Legion
Old 11-11-2021, 06:02 PM
proporsche's Avatar
in the other hand yes 4 is a little too much but again we do not know where did you started with the measurements....
Ivan
Old 11-11-2021, 11:09 PM
