Could I add a second lens to my turn signal?
Recently purchased this car and I know very little about its history. It seems to have a RoW front turn signal lamp, but it's not equipped with a side marker. Can I add another lamp with the rubber trim removed? Or would I have to get a replacement bumper?
Thanks! https://i.imgur.com/iqG2vfth.jpg |
Yes, you can add the side marker light fixtures after removing the fillers.
Check to make sure the single fixture there now has the 2 external connector tabs on it for the side marker fixture wiring to connect to. |
FYI, the side marker does not blink with turn signals, only lights up with parking lights/headlights.
| All times are GMT -8. The time now is 10:30 PM. |
