-   -   Cam advice for 3.2 SS being upgrade from CIS to ITB EFI (http://forums.pelicanparts.com/porsche-911-technical-forum/1085607-cam-advice-3-2-ss-being-upgrade-cis-itb-efi.html)
tommott 02-09-2021 12:57 PM
Hi all,
I'm contemplating a cam swap while I have the motor out of my car for a CIS to the RHD ITB/EFI swap by way of Al at X-faktory. The motor is originally a 3.0 built up to a 3.2 SS with 98mm pistons and cylinders. It is a '78 motor with the large port heads, has SSI exhaust, and has run with the stock SC cams and CIS injection since the motor was first built in 1987. The new ITBs will be run by Megasquirt and ignition by MSD streetfire.
I've done a bunch of searching around the forum and there is a copious amount of info on 3.2ss, cams, etc but I am not finding much info as to what specific cams work with the 98mm CIS pistons. Anybody have a run down of what cams will work and/or recommendations? I see a lot on the GE 40 cams for this setup, but spoke to Dougherty Cams and it didn't sound like the GE 40 cams would clear the 98MM CIS pistons. He recommended the 993 stage 2 cams.
The car will be a street hot rod and will see a lot of spirited driving in the NC mountains, living down the street from the tail of the dragon. Obviously more HP is wanted but still want to have enough grunt in the midrange to pull out of all the endless corners up there. An optimal powerband for an auto-x type/hill climb type car will should work best for my needs.
MichaelSJackson 02-10-2021 08:35 AM
Google "993SS 3.2SS" and you'll find a lot of owners happy with the Dougherty cams in your configuration.
Or Google "993SS 3.2SS Pelican" if you want to focus on the posts from this forum.
tommott 02-10-2021 10:49 AM
Thanks for that. Somehow I had 993 stage 2 cams in my notes but they're actually 993 super sprint cams. Now that I am looking up the correct thing I got all the good info including a dyno chart I was looking for.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/910950-3-2-ss-finally-got-dyno.html
Looks like they're about as aggressive as you can go with CIS pistons and torque starts coming on around 4500 rpms to redline.
David Inc. 02-10-2021 11:47 AM
One thing I've wondered about with new cams and new EFI is how do you do cam run-in? I've always understood that the cams have to be broken in by running the engine at a slightly higher rpm right from the get-go, so what happens if the engine isn't running right and you can't get to the necessary rpm?
jpnovak 02-10-2021 12:36 PM
You get the car started and it may be running less than optimal mixture. Then you raise the rpm so that your breakin process has lots of oil flow and sufficient pressure to flush assembly lube and do your mechanical run-in. During this 20 or so minutes you are tuning on the laptop to refine the mixture. It only takes a few seconds to adjust the mixture. Pretty much a drop in the time bucket compared to the length of time for break-in.
macssc911 02-11-2021 07:00 AM
Not sure on CIS pistons, I run 98 P&C JE 10.5 ,went with Elgin S grind cams with PMO 46s, so just driving around very civilized smooth driver. However if you get an itchy right foot the cams and the carbs marry up around 4K and pull is scary to 7K. Basically it’s a Jeckel and Hyde. I would think with CIS pistons you could go pretty aggressive with cams and still have plenty of clearance.
jpnovak 02-11-2021 07:18 AM
AFIK, there were no 98mm CIS domed pistons. At least not factory ones. There were several versions of a "wedge" style piston which was asymmetric favoring a squish zone on the spark plug side of the head. For example, the 98mm Max Moritz PC set. These 98mm pistons often had valve pockets machined to provide more clearance with high-lift, high duration (AKA Fun!) cam profiles.
Do you have any documentation on what pistons were actually used? A borescope photo of the piston from the spark plug hole at BDC location would also give you an idea what cams could be installed.
Also, Al builds a great kit. It will certainly run better than CIS.
onboost 02-11-2021 07:48 AM
jpnovak is correct... just happen to have some of those sitting around. Both sets are
98mm Mahle Max Moritz.
http://forums.pelicanparts.com/uploa...1613062029.jpg
tommott 02-11-2021 11:17 AM
The only documentation I have is the hand written receipt from the shop that originally built the motor when the pistons and cylinders were first installed in 1987! I guess I could be incorrect but I have always been under the impression that the early wedge shaped 98mm Max Moritz pistons would only clear CIS piston friendly cams?
Hopefully I'll have a borescope pic of the cylinders soon.
Dan J 02-11-2021 03:18 PM
I had a 3.2 ss with 46 webers, Max Moritz pistons and Elgin Mod S cams the valves cleared the pistons with room to spare ( you obviously would have to verify on your motor) it was a great motor
faapgar 02-11-2021 03:39 PM
Max Moritz 98 slant ramp
If you want to use 993RS Cams with Max Moritz you need to make the intake valve pockets 0.60 thousandths deeper.At 4.4 lift at overlap intake valve hits the piston.CiaoFred
faapgar 02-11-2021 03:45 PM
correction
Sorry.When I set cam timing I always check an overrev situation.So I turn the valve adjustment screw 4 half turns then rotate the engine.If nothing touches then life is good.That is 2mm of clearance.With the 993RS cams that is 3mm on the exhaust side.That is plenty of room.Ciao FRED
onboost 02-12-2021 02:26 AM
As a side bar.. - Fred, I get what you're saying with regard to needing the additional clearance in the pocket... but are you saying that the Dougherty 993SS cam is the same spec/profile as 993RS Cams?
Thx
Nux 02-12-2021 02:54 AM
If it is original Max Moritz kit - which is likely if i was done in 1987 - you have 9.3 compression. That and the wedge shaped domes limits your cam choices.
I had the excact same combo in my '78 targa and checked the compression: spot on 9.3.
I used DC20's which is similar to 993SS and car is dynoed at crank 243HP with Thriumph ITBs.
However, to day I would consult William Knight about his Melissa cam or maybe go CatCams. Both seem better in any way.
tommott 02-12-2021 04:25 AM
Thanks for that. Those were my same assumptions; original Max Moritz pistons due to date they were purchased and installed to go along with the original Max Moritz piston cam limitations. Hope to get the pics of the piston domes today. There’s also some handwritten potential part and/or serial numbers under the pistons on the shop’s old school handwritten invoice. I Haven’t had any luck googling those numbers, maybe I can try calling Mahle if worst comes to worst. I’ll post the invoice below in case anybody recognizes those numbers.
Do you happen to have a dyno with the DC20 cams? Cant say I’m entirely pleased with the one dyno chart of a 3.2SS with 993ss cams I saw (linked to above). Awesome power but the torque comes on pretty late. From the charts I’ve seen the GE40 looks to have the best torque curve for the 3.2ss but I believe those supposedly won’t clear the original MM pistons. From what I’ve seen and am aware of that works with the MM pistons at this point, the 964 cans seems to have the best looking torque curve.
http://forums.pelicanparts.com/uploa...1613136214.jpg
Nux 02-13-2021 01:48 AM
The DC20's had to be timed at 1.8@1mm to clear the exhaust valves - not optimal on a low comp engine. So the torque curve is not perfect. Top end is ok.
Again, I would not go this route today. I got the DC's dirt cheap at the time (years ago), so thought I would give it a try. Thats not the correct way to build a good motor.........
To accommodate your new ITBs, I would install new pistons with higher compression and then go for Williams "Melissa" cam.
tommott 02-24-2021 05:54 AM
Thanks for all the help guys. Sorry for the delay in getting back. My buddy did his best with the inspection camera and taking some pics. Hard to make out with 100% certainty with all the carbon build up but it appears that the pistons in the car are mostly flat faced with smaller valve reliefs. Looks like there is a small wedge like the first set of pistons that jpnovak posted. Definitely not a wedge to the extent of the second that jpnovak posted though.
I was not aware that there were different versions of the max moritz 98mm pistons. Am I correct in assuming that I should be running CIS style cams with either version of the MM 98mm pistons?
tommott 02-24-2021 06:26 AM
Here are the from the inspection camera pics
http://forums.pelicanparts.com/uploa...1614178928.jpg
http://forums.pelicanparts.com/uploa...1614179358.jpg
http://forums.pelicanparts.com/uploa...1614180346.jpg
targa72e 02-24-2021 11:30 AM
One of the things you might consider is measuring how much clearance you have with stock cams. Since the adjuster screw is 1.0 pitch each turn is 1mm. You can turn the adjuster in 1/2 turn at a time and rotate the engine by hand with spark plugs removed. When you run out of clearance you will not be able to rotate engine. Knowing the clearance you have with stock SC cams should allow those providing cams to tell you what could work with the pistons you have.
john
Jeff Alton 02-24-2021 07:54 PM
Check out a dyno sheet we posted in the Engine Building Forum of a similar build, twin plug. We ran 10.5:1 CR as we had twin plug. It has the cam choice shown.
We are also building a 3.2 SS with 46PMO carbs right now where John had a very different cam choice due to the 9.5:1 CR.
Contact John at DRCamashafts to get some advice as well.
Cheers
Mark Henry 02-25-2021 04:42 AM
I have a 3.0 twin plug, 120/104 cams with 40 webers that I'm going to be swapping out for EFI. After years of running a simular system with ITB's (different engine) I'm going back to a plenum based intake.
Poor vacuum signal with ITB's is an issue, there are fixes, using a more EFI compatable cam (less duration), running alphaN (TPS only) or in alphaN with limited MAP. These fixes are fine for the race car or even the hot Saturday night hotrod, but if this is a street car, that the wife might drive, or you want to take the car on longer trips....lets just say you may not be as happy with the result of ITB's.
YMMV
