-   -   20 degrees ????? (http://forums.pelicanparts.com/porsche-911-technical-forum/108566-20-degrees.html)
cab83_750 04-29-2003 12:02 PM
20 degrees ?????
I just completed rebuilding all of my brake calipers. What is so magical about ATE's direction of having the pistons oriented at 20 degrees?
pbs911 04-29-2003 12:03 PM
prevents squeeeellll.
masraum 04-29-2003 12:12 PM
it's easy to make a tool yourself with a protractor and some cardboard or sheet metal or thin plywood.
Neilk 04-29-2003 12:19 PM
Or use MS Paint. If you do a search using my name, you will find instructions on how to make the tool if you don't have a protractor.
cab83_750 04-29-2003 12:42 PM
I made one using my "angle finder!" I was asking because my faulty logic tells me that the 'notch' should point down to release accumulation of water when it rains. I guess after 20+ years, even stainless would be 'stainless-no-more.'
Wil Ferch 04-29-2003 12:44 PM
To answer the question...the rotation is important because the pucks are not "square" to the rotor...it's kinda lopsided to provide more ( or less?) force on the leading edge vs trailing edge of the pad. Doing this evens-out the wear of the pad. If the orientation is incorrect, then the natural tendency to get uneven wear will be made even worse. Both Porsche and Mercedes sell a little tool for this for about $10.
---Wil Ferch
Neilk 04-29-2003 12:46 PM
Well, IN MY car there is a tire covering the brakes. ;-)
Don't worry about any accumulation of water. The only time water could theoretically be trapped is when the brakes are applied. Otherwise there is a small gap between the brake piston and the disk.
