Door stay questions
I have seen the door stay replacement kit and the numerous messages on here regarding the door stays. However, all the issue I've seen seem to be when pulling aware from the door itself.
I seem to have the opposite issue where the door stay has pulled away from the chassis on the driver side and is completely separated. I'm confused what the right way is to fix this is.
* Even with the separation on the chassis side, will this kit still work for me ?
* Do I need to find someone to do any welding to make this fix permanent ?
* In order to fix on the chassis side, do I need to remove the drivers side fender first ?
Old 02-15-2021, 02:26 PM
Don't know why my photo didn't attach prior.
Old 02-15-2021, 02:28 PM
Dr J's Avatar
The door stay kit will not work for this damage.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 02-15-2021, 07:32 PM
MBAtarga's Avatar
ouch! bummer. I'd suggest a welding job is in your future.
Mark
'83 SC Targa - since 5/5/2001
Old 02-15-2021, 07:53 PM
Thanks, do you know if I remove the front fender, will that give access to the back side of the door post ?
Old 02-15-2021, 08:14 PM
RETIRED
Joe Bob's Avatar
Yep, likely some custom fabrication sanding and welding a plate for support. Then paint and replacement parts. Not a real big deal but it won't get better by ignoring it. Might want to take a look at the other side while you are at it.
2012 ML350 3.0 Turbo Diesel
Old 02-15-2021, 08:37 PM
