70SWT's Avatar
slant nose LED headlight ideas
I am considering replacing the heavy steel headlight buckets and mechanisms in a pair of slant nose fenders. Why? Benefits I am seeking include light weight, reduced complexity and increased solidity and reliability. If done right, I might even buy back some space for the oil cooler by removing most of the welded-in bucket on the right.
There appear to be a lot of strip-mounted LED kits of likely sufficient strength to serve as at least low beams. These could be mounted transversely across the top inner rear of the residual bucket area and covered with plexiglass.
Anyone done this? Thanks
2018 911 Carrera coupe
1972 911T targa
Old 02-07-2021, 08:25 PM
I think if you`ll search on nissan and mazda forums you might find very interesting ideas and solutions. lot`s of 240sx and rx7 been through that
Old 02-07-2021, 11:21 PM
70SWT's Avatar
Yes, I am seeing some such items out there. There is a good chance I will have to draw from ideas elsewhere or just come up with a custom solution.
But, I'm hoping someone has tackled this on a 911 and can share their experience. There are at least two aspects that need to be gotten right: the lighting itself, and how to create a polycarbonate cover that looks acceptable.
1972 911T targa
Old 02-08-2021, 08:22 AM
Got you. As to the covers - try a guy named Marco Antonio on Facebook (Marco Antonio Garage) he makes some stuff for 944 which may be useful
Old 02-08-2021, 12:11 PM
70SWT's Avatar
That is basically the idea. Looks like those setups have the downturn at the front like a 924/944, whereas the 911 slant nose fenders are essentially flat. Will see what he has.
1972 911T targa
Old 02-12-2021, 12:09 PM
Mr. Merk's Avatar
This is a terrible idea. Just because they make light does in no way make them headlamps.
Utilize Truck-Lite or JW Speaker LED headlamps if you end up doing something like the suggested 944 lamps.
SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS
SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo
Workshop Coordinator at Ehrlich Motorwerks
instagram.com/patrickossenkop
ehrlichmotorwerks.com
Old 02-12-2021, 01:26 PM
70SWT's Avatar
Yeah, that's pretty basic, buddy. Of course, one wouldn't want to use lights of insufficient output and/or inappropriate pattern. Thus, the desire to find folks who have had acceptable results with a particular approach.
1972 911T targa
Old 02-12-2021, 02:00 PM
